Author Topic: Where to buy injection pump seal.  (Read 4052 times)
January 12, 2012, 11:16:11 pm
shwak23
  • 417
    • Blackdog Junkyard
« on: January 12, 2012, 11:16:11 pm »
I need the advance gasket. The PO on my buddys car used liquid gasket stuff and it's leaking. Where do I get the seal or gasket or whatever? Actually I need the front one as well. Same plate on the front is leaking.
Reply #1January 13, 2012, 08:15:33 am
Re: Where to buy injection pump seal.
« Reply #1 on: January 13, 2012, 08:15:33 am »
Giles sells the kits.. but if you r looking for a quick to your door type of thing.. I would try Prothe. emiata.com
Reply #2January 13, 2012, 03:38:52 pm
shwak23
  • 417
    • Blackdog Junkyard
« Reply #2 on: January 13, 2012, 03:38:52 pm »
Oh I see there is a O Ring there and not a gasket... Hmmm... Guess I will just put in a new o ring.... Duh. DX
Reply #3January 16, 2012, 05:37:43 pm
DieselBalz
  • 301
« Reply #3 on: January 16, 2012, 05:37:43 pm »
Is that peretty much the only place you can get them? I am heavily considering the gov mod, and was just thinkin about where I wuold get the gasket for the top.
Reply #4January 16, 2012, 05:42:23 pm
« Reply #4 on: January 16, 2012, 05:42:23 pm »
If you are only going to do the pump top when removing the top for the gov mod..
I have had EXCELLENT luck with just reusing the seal and some fuel safe gasket maker. Avery thin thin bead and it will seal better than a new seal.
Reply #5January 16, 2012, 05:43:07 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Where to buy injection pump seal.
« Reply #5 on: January 16, 2012, 05:43:07 pm »
I'll probably just be ordering one from ol' proethey. I'm sire it would be fine. I've ordered a motor mount from him. It was fine. Hard to *** up a ball of rubber though.
Sent from my DROID X2 using Tapatalk
Reply #6January 22, 2012, 03:33:43 pm
Baron VonZeppelin
« Reply #6 on: January 22, 2012, 03:33:43 pm »
okay
damm lol
You can get Bosch kits for same or less than Prothe Hans.
and..... they're BOSCH with Viton, instead of ??
Yellow Pages for Auto / Diesel
eBay seller sam the diesel man
http://motors.shop.ebay.com/sam_the_diesel_man/m.html?_trksid=p4340.l2562
Fuel shops, and Sam, will both sale individual Bosch seals/gaskets if you just want a certain something.
Bosch Kits
DGK 126 for Basic style pumps
DGK 121 for TD and the 88-92 Altitude Aneroid pumps
Correct Front seals are usually sold seperately from kits now.
Sam usually includes them
Inquire
