Author Topic: Injector pump seal kit  (Read 4620 times)
February 06, 2006, 06:04:35 pm
Luckypabst
  • 502
« on: February 06, 2006, 06:04:35 pm »
Newbie here that needs a bit of direction (search didn't answer my specific question)...
For trivia's sake this is for an '82 Westy with 1.6l turbo diesel.
I'm trying to locate locally a seal kit for the injector pump. I've seen the various part numbers posted here but don't know where to actually get the kit. A call to a couple local VW dealers proved fruitless...
The pump is leaking somewhere around the body - from reading old posts here, I'm guessing it's the cold start shaft but I can't verify that. Peeking under the timing cover reveals clean, dry conditions and the pump should only have about 20K on it so I figure it's in otherwise fair shape.
In the event I can't come up with a ready made kit, does anyone know the dimensions of whatever o-rings are in there so I can have them in hand before tearing into the thing?
Thanks
Chris
'82 TD Westy
'81 NA Caddy
Reply #1February 06, 2006, 06:33:56 pm
bryanbryan89x
  • 110
« Reply #1 on: February 06, 2006, 06:33:56 pm »
Probably any local diesel injection shop can get you what your looking for.  I bought my gasket kit at Superior Diesel and Injection in Detroit ($18.80).
Here is a link to locate one in your area...
http://www.boschservice.com/public/servicelocation/DSCautomotive.html
1981, Rabbit Car, 1.6, N.A.
Reply #2February 06, 2006, 08:08:20 pm
Luckypabst
  • 502
« Reply #2 on: February 06, 2006, 08:08:20 pm »
Excellent! Thank you, found a place in the next city.
Chris
'82 TD Westy
'81 NA Caddy
