Author Topic: Tire fitment, a few questions if you will.  (Read 6903 times)
January 10, 2012, 12:17:34 pm
« on: January 10, 2012, 12:17:34 pm »
I think I recall you having a balloon of a tire ed.. what size was it? I was looking at some 195/70/14 summitomo's to put on my snowflakes for my 84 jetta. I was wondering if they'd fit on there in place of my 185/60/14's.
http://www.miata.net/garage/tirecalc.html
This website says they wont be too much bigger, and I don't think I have any clearance issues upwards, it would be a much wider tire that would be the issue..
« Last Edit: January 11, 2012, 10:24:16 pm by 8v-of-fury »
Reply #1January 10, 2012, 01:10:48 pm
Re: SMOKEY EDDY! Tire fitment, a few questions if you will.
« Reply #1 on: January 10, 2012, 01:10:48 pm »
i had some 185/70/14s, and they were HUGE.. they rubbed, and were just too big for the car.. this was on a stock height mk2. they REALLY RUBBED on my mk1..
and a 195/70/14's are even bigger, so i imagine they would rub even worse..
Reply #2January 10, 2012, 03:32:25 pm
guy plain
  • 121
« Reply #2 on: January 10, 2012, 03:32:25 pm »
my mk2 has 185,s no rubbing.....turned down a set of 195,s cause i think they would rub...some one on this site had 195,s and they did say athat there was rubbing but it was in the back ???  so im no sure..but my 185,s do clear every thing....its a 92 mk2...if that means any thing lol
Reply #3January 10, 2012, 04:04:18 pm
« Reply #3 on: January 10, 2012, 04:04:18 pm »
195 what?
what size wheel?
mk2s have bigger wheel wells than mk1 cars FWIW..
Reply #4January 10, 2012, 04:24:40 pm
spencebm
  • 686
« Reply #4 on: January 10, 2012, 04:24:40 pm »
I run 205s on a stock 6" wide et 35 rim and they aren't even close to rubbing on my mk2.
Ben Spencer
Reply #5January 10, 2012, 05:10:59 pm
guy plain
  • 121
« Reply #5 on: January 10, 2012, 05:10:59 pm »
CRAP!!!  i missed that you where talking about a mk1... oops.... :-[
Reply #6January 10, 2012, 07:15:59 pm
  • 4553
« Reply #6 on: January 10, 2012, 07:15:59 pm »
I have 185 70R 14's on my MK1 and they don't rub.  And I have had it pretty close to the GVW recently.
They fill the wheel well up with about an inch front and back but the top clears well.
Reply #7January 10, 2012, 07:17:11 pm
« Reply #7 on: January 10, 2012, 07:17:11 pm »
205 whats? what size wheel?
i had 205/40/17's on 17x7 wheels on my mk2, and they almost rub the strut tower.. any bigger tire, or wider wheel and they would be rubbing the strut.
Reply #8January 10, 2012, 07:26:11 pm
« Reply #8 on: January 10, 2012, 07:26:11 pm »
you got em on 'flakes tho.. prolly a little farther in the fender than mine. my tires always rubbed the arches of the fender..
mine were on ET25 Enkei 92s in 14x6 size..
Reply #9January 10, 2012, 07:29:49 pm
  • 4553
« Reply #9 on: January 10, 2012, 07:29:49 pm »
Yeah they are tucked inside the wheel well rather nicely.  Any offset would cause them to rub now that I think about it.
I can pass my fingers over the tire and not hit the body anywhere.
Reply #10January 11, 2012, 10:49:07 am
« Reply #10 on: January 11, 2012, 10:49:07 am »
so you have your 185/70/14 on 14" snowflakes? It doesn't matter if the wheels will require more torque to turn, its gonna be m-tdi powered lol. thank-you for your help :).
Reply #11January 11, 2012, 10:56:32 am
« Reply #11 on: January 11, 2012, 10:56:32 am »
yea, my Enkeis arent stock VW offset.. thats my problem.
Reply #12January 11, 2012, 05:17:34 pm
  • 4553
« Reply #12 on: January 11, 2012, 05:17:34 pm »
Yes indeed I do.  This is the look, and I have the Zender kit attached as well.  Forgot about that.  Blended it so nice with the paint job I forget it is an addition not stock.
« Last Edit: January 11, 2012, 05:20:53 pm by ORCoaster »
Reply #13January 11, 2012, 10:21:13 pm
« Reply #13 on: January 11, 2012, 10:21:13 pm »
do you have the stock springs? From 1981 I mean rather. that will account for some sag.
When i put on my 25mm drop sport springs it maintained the ride height i had from stock prior, the stock springs had settled an inch or more.
Reply #14January 12, 2012, 06:35:21 am
  • 4553
Re: Tire fitment, a few questions if you will.
« Reply #14 on: January 12, 2012, 06:35:21 am »
With 126K on this car I believe the rear springs are still stock and there is little to no sag.  Until I move the tool boxes to the rear of the car.  Normally I ride them in front or over the rear axle.
Yeah this car doesn't seem to have that normal butt dragging look that I have seen on other Rabbits.
