Author Topic: Quick question on head gasket  (Read 2193 times)
January 09, 2012, 09:26:32 am
clbanman
  • 705
    Cambridge, Ontario
« on: January 09, 2012, 09:26:32 am »
I have a chance to buy a Golf that had an "engine rebuild".   It looks like it was a re-ring and bearing replacement with new timing belt.   Seller says oil is getting into the coolant - says it's the head gasket.   What are the odds that this could be fixed by just re-torquing the head bolts?
Calvin
91 VW Golf 1.6NA 5spd
Reply #1January 09, 2012, 09:29:13 am
monomer
  • 414
Re: Quick question on head gasket
« Reply #1 on: January 09, 2012, 09:29:13 am »
Gaskets easy to replace.
If it has an oil cooler, I would start there. I've heard of many failing and leading to a milkshake...
www.michiganvw.org
Reply #2January 09, 2012, 12:54:23 pm
rodpaslow
  • 670
« Reply #2 on: January 09, 2012, 12:54:23 pm »
My experience, just about nothing is fixed by re-torquing, but that would depend on the mechanic that was working on it.  Odds are it needs a new head gasket (minimum) to possibly a new head if it was over-heated & warped.  My .02$
Reply #3January 09, 2012, 02:24:36 pm
« Reply #3 on: January 09, 2012, 02:24:36 pm »
x2..
had it happen to me a couple times..
replace/eliminate cooler and your on your way.
