Author Topic: $5 home built centrifuge for WVO and all that other good stuff  (Read 13208 times)
January 04, 2012, 06:59:30 pm
« on: January 04, 2012, 06:59:30 pm »
Alright, $4.50 if you don't count the glue sticks and epoxy. I'm currently testing the bowl to make sure it doesn't have any leaks. Pending good results, some time tomorrow afternoon I'll actually try and filter some oil. Of course I'll post some pictures if I can a) find a camera and b) it actually works.
Reply #1January 04, 2012, 08:53:04 pm
Re: $5 home built centrifuge for WVO and all that other good stuff
« Reply #1 on: January 04, 2012, 08:53:04 pm »
Tyler, you need to make this work. DO IT.
I would love to be able to take peoples old oil change oil and filter it out.
YOU ARE THE MAN! I'll give you $50 to make me one. lol
Reply #2January 04, 2012, 09:09:56 pm
diesel smoke
  • 209
« Reply #2 on: January 04, 2012, 09:09:56 pm »
Watching.  ;)
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #3January 05, 2012, 06:45:14 am
wdkingery
  • 494
« Reply #3 on: January 05, 2012, 06:45:14 am »
+73 on this right here. i have everything but the centrifuge, and am waiting on finding $160 to get one from www.pabiodieselsupply.com ... BUT if you have crafted a way to make them for $5, well good God tell us!!
Reply #4January 05, 2012, 11:42:12 am
« Reply #4 on: January 05, 2012, 11:42:12 am »
Well preliminary tests resulted in a 50% failure, so I'm pulling out the glue sticks again and will report back soon (I hope)
Reply #5January 05, 2012, 11:43:40 am
« Reply #5 on: January 05, 2012, 11:43:40 am »
well, atleast it only half ways failed  ;D
Reply #6January 05, 2012, 01:23:13 pm
« Reply #6 on: January 05, 2012, 01:23:13 pm »
It got a little more exciting in the kitchen, but not in the good sense. Not surprisingly, balance plays a pretty big role in this. I was able to see that it would work if I had a bowl that was balanced. Since my bowl was so far from balanced, once it started getting up to speed the whole unit starting shaking and vibrating like crazy. It felt like a jumbo jet was taking off. So the next order of business will be to take it to a machine shop and see what they would charge to spin up a bowl. I'm definitely going to blow my $5 budget though unless I can convince one of my machinist friends otherwise... I'm glad I was testing with water instead of oil or I would have made quite the mess.
wdkingery I was looking at those centrifuges initially (although by a different company) and I really don't like the idea that you have to heat the oil first. My thoughts are, anything that is solid at colder temps but not once heated is going to cause problems in the pump/engine/injectors/filter if you don't do a complete flush on cool-down, or if you don't get your oil hot enough.
Reply #7January 05, 2012, 02:06:49 pm
« Reply #7 on: January 05, 2012, 02:06:49 pm »
http://www.innovativebalancing.com/index.php
Don't put the solids in any fancy filtering equipment....I prefer to leave them in the vat.
Reply #8January 05, 2012, 03:09:47 pm
whoabeats
  • 38
« Reply #8 on: January 05, 2012, 03:09:47 pm »
I just had to recycle all my old truck oil that had collected in the garage. It was over ten gallons. It would be awesome to turn a fraction of that into fuel.
I have a diesel hot-rod addiction
97 2500 cummins 4x4 5 speed 460hp
98 AHU m-tdi being built for a car I dont own
00 ALH TDI handles like a race car, but has no balls
Reply #9January 06, 2012, 04:04:35 am
RustyCaddy
  • 395
« Reply #9 on: January 06, 2012, 04:04:35 am »
Some folks will suspend small centrifuges (like a modified Acme Juicerator) from the ceiling to get around the vibration problems
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/159605551/m/1681017591?r=1961065312#1961065312
Reply #10January 07, 2012, 07:13:35 am
« Reply #10 on: January 07, 2012, 07:13:35 am »
That's exactly what I was using, except not an ACME. The bowl I had needed to be modified to have a lid. I wonder if I suspended mine if it would work. Thanks for the link.
Reply #11February 13, 2012, 05:12:56 pm
« Reply #11 on: February 13, 2012, 05:12:56 pm »
TYLER. Did this ever pan out? Just got my hands on a few 55gallon drums.. really lookin in to burning WMO.. Got a source for A LOT of it too..
LEmme know whats up Tiko- Bromontana.
Reply #12February 17, 2012, 10:06:38 pm
Baron VonZeppelin
« Reply #12 on: February 17, 2012, 10:06:38 pm »
Would it help if the bar was raised to $20-25 ?
I need a centrifugical spinning filtering apparatus too.
Reply #13February 23, 2012, 02:10:18 am
« Reply #13 on: February 23, 2012, 02:10:18 am »
Had I read this article before packing up the project I may have succeeded. Things have come up and then project is on the back-burner at the moment.
Reply #14February 23, 2012, 10:23:18 am
mtrans
  • 308
« Last Edit: February 23, 2012, 10:27:09 am by mtrans »
I`ll improve my English
