Author Topic: Fs: stock mk3 tdi Sidemount intercooler+piping  (Read 7209 times)
January 03, 2012, 12:57:26 pm
gtidiesel1.6
  • 72
« on: January 03, 2012, 12:57:26 pm »
I have a stock mk3 side mount intercooler with the ducting.
It comes with the stock pipes and couplers
$80 shipped, pics avalible by request.
« Last Edit: February 28, 2012, 11:41:51 pm by gtidiesel1.6 »
Reply #1January 07, 2012, 06:59:58 am
dieselweasel
  • 312
Re: Fs: stock mk3 tdi Sidemount intercooler+piping
« Reply #1 on: January 07, 2012, 06:59:58 am »
I'm interested if you still have this.
Reply #2January 08, 2012, 09:49:50 pm
gtidiesel1.6
  • 72
« Reply #2 on: January 08, 2012, 09:49:50 pm »
Sure do!
Reply #3January 11, 2012, 03:25:19 am
dieselweasel
  • 312
« Reply #3 on: January 11, 2012, 03:25:19 am »
PM sent
Reply #4January 18, 2012, 08:35:50 am
gtidiesel1.6
  • 72
« Reply #4 on: January 18, 2012, 08:35:50 am »
Reply #5January 18, 2012, 07:41:51 pm
« Reply #5 on: January 18, 2012, 07:41:51 pm »
think this could be fitted to a mk2 car fairly easy?
Reply #6January 18, 2012, 08:13:27 pm
« Reply #6 on: January 18, 2012, 08:13:27 pm »
very easily Kev, they are pretty much the same under the hood with placement of stuff. You may have to cut the tubes short for where they go under the battery and run your own rubber hose to the inter cooler.. but it would fit pretty good id think.
Reply #7January 18, 2012, 08:30:48 pm
« Reply #7 on: January 18, 2012, 08:30:48 pm »
where does it actually mount up?
and how much boost will a stock core hold, before the plastic tanks blow off?
TDIs run a considerable amount of boost dont they? north of 20psi?
Reply #8January 18, 2012, 08:34:01 pm
« Reply #8 on: January 18, 2012, 08:34:01 pm »
It mounts in front of the driver tire. Side mount intercooler.
this is an AHU ic setup, drivers side determines it. ALH had it on the passenger.
AHU's run 12-14psi stock from their k03's
Reply #9January 18, 2012, 08:58:02 pm
« Reply #9 on: January 18, 2012, 08:58:02 pm »
think i would explode it with my VNT?
Reply #10January 18, 2012, 08:59:53 pm
« Reply #10 on: January 18, 2012, 08:59:53 pm »
people run 18-20 psi out of a k03..  but you run like high 20's no?
Reply #11January 18, 2012, 09:11:41 pm
« Reply #11 on: January 18, 2012, 09:11:41 pm »
mid-high 20s..
Reply #12January 18, 2012, 10:15:40 pm
« Reply #12 on: January 18, 2012, 10:15:40 pm »
not to kill a sale here... but fitting to a mk2... way more work... the first tdi conversion i did was in a mk2... unless you got big bumpers.. not happening... and the batt needs changed.. i used the mk3 mount and moved it sideways but it will not in no way fit under the fender.. gotta cut it and use the big bumper to hide it away..
Reply #13January 18, 2012, 10:39:31 pm
gtidiesel1.6
  • 72
« Reply #13 on: January 18, 2012, 10:39:31 pm »
Thanks for all the replies/info people.
I had it in a mk1 with a slight scoop in the hood and placed the cooler where the battery was(even before the scoop my intake temps went down and aswell with egt)
Friend of mine also has the same cooler/pipes and a few aftermarket couplers to stick it into the driver side fender well(plastic liner was cut up a little to make it fit) on his mk2 jetta
« Last Edit: January 19, 2012, 10:12:43 pm by gtidiesel1.6 »
Reply #14January 19, 2012, 04:51:24 pm
« Reply #14 on: January 19, 2012, 04:51:24 pm »
i got big bumpers, but im not liking what your saying.. its not gonna look like its supposed to be there, is it?
