Author Topic: TDI Help!!!  (Read 4886 times)
December 29, 2011, 01:55:23 pm
catlin_cava
  • 1954
TDI Help!!!
« on: December 29, 2011, 01:55:23 pm »
so before i take it to the dealer id like to try and figure out WTF is going on,
the other day i had a 000564 code Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
I checked all my Vacuum lines, Actuator holds vaccuum, cant see any leaks in the Vac lines, checked all the intercooler tubing
when i would drive, around 2200RPM the car would start hesitation and surging, i would hit 3300RPM and the car would take off like a rocket,
havent drove the car in a couple days, today the car worked GREAT!!! went down to the store on the way back BOOM limp mode >:( got home and scanned it. 000665 - Boost Pressure Regulation: Control Range Not Reached
this is a 2006 Jetta TDI BRM engine code,
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1December 29, 2011, 04:16:02 pm
rallydiesel
  • 1880
Re: TDI Help!!!
« Reply #1 on: December 29, 2011, 04:16:02 pm »
Can you move the vane actuator? Pretty hard to reach on the BRM but can be done.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2December 29, 2011, 04:29:20 pm
catlin_cava
  • 1954
Re: TDI Help!!!
« Reply #2 on: December 29, 2011, 04:29:20 pm »
yea, i can move it with a screw driver no problems.
Catlin
Reply #3December 29, 2011, 04:35:57 pm
rallydiesel
  • 1880
Re: TDI Help!!!
« Reply #3 on: December 29, 2011, 04:35:57 pm »
Is there a lot of soot around the egr cooler flap valve actuator?
Reply #4December 29, 2011, 07:31:50 pm
catlin_cava
  • 1954
Re: TDI Help!!!
« Reply #4 on: December 29, 2011, 07:31:50 pm »
where is that??
Catlin
Reply #5December 30, 2011, 02:10:57 pm
rallydiesel
  • 1880
Re: TDI Help!!!
« Reply #5 on: December 30, 2011, 02:10:57 pm »
If you look from under the car, you can see an actuator that closes off the egr path to the egr cooler. It should be covered by a fabric heat shield. The bushing often leaks and hot egr gases blow out coating surroundings in soot and causing low boost. It also tends to whistle around 2000 rpm.
