Author Topic: Annoying Noise from the Fusebox >:-(  (Read 7274 times)
Reply #15February 07, 2006, 09:22:08 am
HP
  • 225
« Reply #15 on: February 07, 2006, 09:22:08 am »
Quote from: "BlackTieTD"
my guess for you would be signal relay or glow plug relay.
By this way, I would say the glow plug relay. The engine even takes a little bit longer to start than normal, when this sh*tty buzz sounds!  :wink:
Also it doesn't sound as a turn signal "beep"!
"signal relay" - is the turner lights (blinkers) relay is that?
Reply #16February 07, 2006, 09:36:13 am
BlackTieTD
  • 1512
« Reply #16 on: February 07, 2006, 09:36:13 am »
ya, turn signal, signal relay, blinkers......all the same  :)
my signal relay made a weird noise too... not like the clicking it normally makes, more like a buzz.
either way, try to find those two relays and pull them 1 at a time, see if the buzz goes away. do you have a bentley manual or diagram of the relays for your car? sometimes the names are printed on the fuseblock.
Reply #17February 07, 2006, 09:43:44 am
HP
  • 225
« Reply #17 on: February 07, 2006, 09:43:44 am »
No, I dont hav any manual. :S
but thanks everyone for the replies! : )
