Author Topic: #3 injector line keeps cracking  (Read 4347 times)
December 22, 2011, 11:17:10 am
lucasone
  • 25
« on: December 22, 2011, 11:17:10 am »
Has anyone ever had this problem? I have a 1.9 TDI (AHU) that has a vibration that I can feel throught the throttle pedal only. When it vibrates it takes out the #3 injector line. It cracks just above the fitting on the injector.
I have gone through 3 lines in the past 2 months. I checked the engine mount and the exhaust to see if any thing is touching and it all looks good.
Also I do have the injector line clips holding them together to prevent vibration.
Any ideas? Injection pump?
Reply #1December 22, 2011, 06:42:40 pm
CdnVWJunkie
  • 309
Re: #3 injector line keeps cracking
« Reply #1 on: December 22, 2011, 06:42:40 pm »
Check the back injection pump bolt as well as the mount itself.  I've seen a couple crack mounts before which caused cracked number three lines too.
GL.
Reply #2January 23, 2012, 07:31:18 pm
dieselherb1
  • 354
« Reply #2 on: January 23, 2012, 07:31:18 pm »
Had the same problem turned out to be pump bolts not tight
