Author Topic: compatable clutches for aaz in 93 golf  (Read 3512 times)
December 19, 2011, 04:56:47 pm
xxkoadyxx
  • 179
« on: December 19, 2011, 04:56:47 pm »
I'm wondering what clutches I can use in my 1.9TD without modifications? My clutch in my car needs to be replaced as its slipping..
Thanks guys :)
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #1December 19, 2011, 08:54:22 pm
Re: compatable clutches for aaz in 93 golf
« Reply #1 on: December 19, 2011, 08:54:22 pm »
Are you sure it's not just the silly auto adjusting cable messing up?
Reply #2December 20, 2011, 04:37:48 am
regcheeseman
  • 714
« Reply #2 on: December 20, 2011, 04:37:48 am »
The AAZ is a 210mm flywheel IIRC - just replace it with a decent replacement AAZ clutch?
Unless you want to change the flywheel? I think I'm using a TDI fly with a HD 16V gasser 228mm plate
Reply #3December 20, 2011, 05:50:45 am
stewardc
« Reply #3 on: December 20, 2011, 05:50:45 am »
I got an ACT setup for my AAZ. It's sweet and it'll handle any mod I want to make to the engine.
Reply #4January 09, 2012, 07:54:35 am
xxkoadyxx
  • 179
« Reply #4 on: January 09, 2012, 07:54:35 am »
is the 1.9 a 2 dowel flywheel?
im looking at getting this http://www.autopartsway.ca/PartList.cfm?Volkswagen/1993/Golf/Base/1.9L_L4/allB/Transmission_and_Transaxle_-_Manual/Manual_Transmission_Components/Clutch_Pressure_Plate/pagenum1/tabS
matched with a ACT clutch.. How would that work? what else would i need? Do i need new bolts and such for the flywheel ect? also plan on doing this also sense i have it apart- http://www.autopartsway.ca/partlist.cfm?Volkswagen/1993/Golf/Base/1.9L_L4/allB/Transmission_and_Transaxle_-_Manual/Manual_Transmission_Components/Clutch_Push_Rod_Seal
What is your guys thoughts? Any thing else i should do sense i have it apart?
thanks! koady :)
« Last Edit: January 09, 2012, 07:58:52 am by xxkoadyxx »
Reply #5January 09, 2012, 09:27:41 am
« Reply #5 on: January 09, 2012, 09:27:41 am »
x2..
the auto cables are JUNK..
and often take out clutches early.
Reply #6January 09, 2012, 09:29:53 am
stewardc
« Reply #6 on: January 09, 2012, 09:29:53 am »
Mine is 2-pin and that pressure plate should work nicely on a stock motor. That is the stock PP. If the motor is stock, simply use the OEM clutch disc also.
Reply #7January 09, 2012, 09:47:58 am
xxkoadyxx
  • 179
« Reply #7 on: January 09, 2012, 09:47:58 am »
alright thanks! well i ordered the pressure plate..
The motor is stock-ish, 1.6 boost pin, fuel up some, boost up some, stright pipe with muffler and TDi intercooler (soon) and intake
Reply #8January 09, 2012, 09:54:56 am
« Reply #8 on: January 09, 2012, 09:54:56 am »
you can use a 16v clutch and pressure plate also..
i know the 16v pressure plate is the best/strongest one you can get in terms of stock 020 pressure plates..
Reply #9January 09, 2012, 10:18:53 am
xxkoadyxx
  • 179
« Reply #9 on: January 09, 2012, 10:18:53 am »
alright, thanks!  8)
