Author Topic: OOPS...  (Read 7051 times)
December 19, 2011, 01:10:04 pm
OOPS...
« on: December 19, 2011, 01:10:04 pm »
so, my TD is F*****... ROYALLY!
the timing belt broke, the cam broke. yadda yadda..
im sad.
« Last Edit: December 19, 2011, 01:30:34 pm by R.O.R-2.0 »
Reply #1December 19, 2011, 01:11:37 pm
guy plain
  • 121
Re: OOPS...
« Reply #1 on: December 19, 2011, 01:11:37 pm »
OH SHART!! that sucks balls....
Reply #2December 19, 2011, 01:34:11 pm
Re: OOPS...
« Reply #2 on: December 19, 2011, 01:34:11 pm »
pulling the head as we speak.
i dont feel too good about it tho, i have a feeling this engine is toast. i mis-shifted 4th gear, and grabbed second. i was at the very top of 3rd gear when i had the mis-shift. im gonna say that the engine must have been turning 8-9000 revs when it went down...
im going to be AMAZED if the bottom end isnt messed up..
all i want for christmas, is coal! well, to be able to pour coal again...
Reply #3December 19, 2011, 02:13:31 pm
Re: OOPS...
« Reply #3 on: December 19, 2011, 02:13:31 pm »
Yowza... Do you think the t-belt broke, or that lifter got stuck in its bore causing the t-belt to get broken?  Downright nasty either way!!  Must have sounded interesting...
Reply #4December 19, 2011, 03:07:13 pm
Re: OOPS...
« Reply #4 on: December 19, 2011, 03:07:13 pm »
the engine died a quiet death, believe it or not.. didnt even crunch that badk just clattered a little bit, and the fire was gone from the engine..
i expected to find all the adjuster pucks laying in the head.
idk what happened first. my timing belt was a bit soft from a fuel leak, but im thinking that the lifter broke, and stopped the cam, then the pistons came up, whammy'd the valves, and busted the cam to bits. i ended up with 4 chunks, 1 piece is half the cam, one piece is a quarter of it, and the last 2 pieces are about 1/8th of the cam..
Reply #5December 19, 2011, 04:53:57 pm
Re: OOPS...
« Reply #5 on: December 19, 2011, 04:53:57 pm »
What are you goona do now k3vo!? that aaz you got sitting?
Reply #6December 19, 2011, 05:05:38 pm
Re: OOPS...
« Reply #6 on: December 19, 2011, 05:05:38 pm »
Oh lawdy  :o :o
Reply #7December 19, 2011, 06:42:47 pm
Re: OOPS...
« Reply #7 on: December 19, 2011, 06:42:47 pm »
buddy that's serious.  :o
Reply #8December 19, 2011, 07:03:18 pm
  • 4553
Re: OOPS...
« Reply #8 on: December 19, 2011, 07:03:18 pm »
And we all know what Santa knows, you have not been good this year so no new engines under the tree for you.
That is one mess of metal there my friend.  But I know you have the ability to make a swap and if it won't be as good it will be better.  It will run again.
Had a mis-shift myself getting off I-5 at Salem.  5th to 2nd.  I was looking for 4th on the exit ramp and just as I was starting to play the clutch I thought NO that is to far west with the shifter.  Left foot down hard.  Just barely revved it.  Nothing like that scrap pile of yours.
Sorry man, SH.
Reply #9December 19, 2011, 10:56:59 pm
maxfax
  • 2126
Re: OOPS...
« Reply #9 on: December 19, 2011, 10:56:59 pm »
Want me to come out there and weld that back together for you??  ;D
Reply #10December 20, 2011, 07:06:18 am
Re: OOPS...
« Reply #10 on: December 20, 2011, 07:06:18 am »
Looks like the cam gear is still on...you didn't hit it sharply at 90 degrees to get it off did you LOL.
In all reality I think maxfax is on to something...a little weld and I think that will buff right out...
Reply #11December 20, 2011, 09:12:06 am
Re: OOPS...
« Reply #11 on: December 20, 2011, 09:12:06 am »
so, a little over 12 hours after i blew it up, i also got it running again!!
i got to hear it running before i went to sleep last night, i was completely satisfied!
all i did was replace the head and belt. i took the head off my TD block. didnt know my rabbit had a 12mm engine, i always thought it had a 11mm vanagon engine. anyways, i started looking at the block and head bolts, and sure as hell, there 12mm bolts!
my engine has a 17mm crank bolt, and says 16D on the back of the block.
17mm 6 pt crank bolt, 16D on back of block = usually 11mm block
19mm 12pt crank bolt, 1.6D on back of block = usually 12mm block
anyways, back to the engine at hand. i was in such a hurry to put it back together that i didnt have time to snap pics of the light valve kisses that were on the piston crowns.
another thing! remember how i seized this engine up about a year or so ago? yea, well the bores still look fine amazingly!
im building an AAZ head for this sucker now!
Reply #12December 20, 2011, 09:21:04 am
Re: OOPS...
« Reply #12 on: December 20, 2011, 09:21:04 am »
That's awesome
Reply #13December 20, 2011, 09:46:05 am
Re: OOPS...
« Reply #13 on: December 20, 2011, 09:46:05 am »
so this whole time you been telling everybody you were boosting the hell out of an 11mm block.. it wasn't really an 11mm block.. lol
AWESOME THOUGH! friggen eh its a 12mm and friggen eh that your building a 1,9 head :) WOOHOO this was the perfect break down.
Reply #14December 20, 2011, 09:56:46 am
Re: OOPS...
« Reply #14 on: December 20, 2011, 09:56:46 am »
this whole time i thought i had 11mm bolts. and ive boosted an 11mm block way higher than this thing.. this block has seen ~22psi..
my old 1.5 saw 30+ psi regularly.. 11mm bolts.
anyways, this vanagon engine in my car, it has all the markings of an 11mm block, so i assumed it was an 11mm block with gasser bolts.
WRONG! its 12mm!
