Author Topic: Bosch VE Injection Pump Resealing Service  (Read 34431 times)
December 18, 2011, 02:19:32 pm
« on: December 18, 2011, 02:19:32 pm »
The pumps will be completely dissembled, resealed using 100% genuine OEM Bosch DGK 126 kits, cleaned up and setup to within original stock settings. I will also adjust the pressure regulator for proper dynamic advance. Each pump needs small fine adjustments to run properly on your engine as each one is completely different in adjustments needed. Also note this is not a rebuilt pump, this is merely a resealing service for the time being. Everything that I take out of the pump I put back in, nothing new. These are sold as-is, my time is non-refundable.
I offer an affordable service of resealing pumps you already have as well. I have experience in all Volkswagen VE pumps(1.5, 1.6NA/TD, 1.9AAZ, and 1.9TDI), 2.5 Land Rover pumps, and 505 Peugeot pumps. You pay shipping both ways, the cost of the seal kit, and a couple hours of my time. Although I have not had any actual experience with the Cummins Bosch pumps I am fairly confident I can reseal them too.
The pictures in this thread are my own pictures that directly reflect my work done.
___________________________________________________________________________________________________________________
NOTE: The red date below is my current stock
November 4th 2013
1 - 1.6 TD pump
3 - 1.6 NA pumps
1- 1.9 TDI AHU parts pump
TONS OF RESEAL KITS!
PM ME FOR MORE DETAILS :)
Land Rover Discovery 300TDI pump, for my M-TDI. Polished.
ONLY BOSCH GENUINE SEAL KITS :)
1.9 AHU, fully functional electronics. You get what is pictured. Vane pump is good, and it has a new shaft seal in case. This pump made proper pressures when it ran.
FOR SALE $150 USD + shipping
« Last Edit: November 04, 2013, 08:21:46 pm by 8v-of-fury »
Reply #1January 11, 2012, 05:22:00 pm
Re: FS: Resealed 1.6 IDI pumps
« Reply #1 on: January 11, 2012, 05:22:00 pm »
#1 SOLD
#2 SOLD with #3 SOLD in the background.
« Last Edit: May 14, 2012, 07:47:49 pm by 8v-of-fury »
Reply #2March 22, 2012, 10:12:50 pm
« Reply #2 on: March 22, 2012, 10:12:50 pm »
#4 - SOLD
« Last Edit: May 14, 2012, 07:48:03 pm by 8v-of-fury »
Reply #3March 23, 2012, 04:42:06 pm
« Reply #3 on: March 23, 2012, 04:42:06 pm »
#5 - SOLD
« Last Edit: May 14, 2012, 07:48:16 pm by 8v-of-fury »
Reply #4May 14, 2012, 08:25:30 pm
Re: FS: Resealed 1.6 & 1.9 IDI pumps
« Reply #4 on: May 14, 2012, 08:25:30 pm »
#6 -SOLD
« Last Edit: July 31, 2012, 08:51:53 am by 8v-of-fury »
Reply #5May 17, 2012, 07:40:03 pm
« Reply #5 on: May 17, 2012, 07:40:03 pm »
#7 - SOLD!!
« Last Edit: June 11, 2012, 06:08:19 pm by 8v-of-fury »
Reply #6June 19, 2012, 07:44:39 pm
« Reply #6 on: June 19, 2012, 07:44:39 pm »
#8 - SOLD!! This one had 1.9 AAZ guts put in to the 1.6 TD pump body. Steeper cam plate, better rollers, and much stiffer springs as can be seen on the right, left pieces are stock 1.6 TD equipment.
« Last Edit: June 30, 2012, 08:15:18 am by 8v-of-fury »
Reply #7January 17, 2013, 09:44:58 pm
Re: Bosch VE Injection Pump Resealing Service
« Reply #7 on: January 17, 2013, 09:44:58 pm »
#9 - SOLD!!
Reply #8January 17, 2013, 09:47:30 pm
« Reply #8 on: January 17, 2013, 09:47:30 pm »
#10 Peugeot 505 pump ;) Still a work in progress..
Reply #9January 17, 2013, 09:49:29 pm
« Reply #9 on: January 17, 2013, 09:49:29 pm »
#11 - SOLD
Reply #10March 11, 2013, 06:17:57 pm
« Reply #10 on: March 11, 2013, 06:17:57 pm »
#12 - SOLD
« Last Edit: April 13, 2013, 08:18:10 am by 8v-of-fury »
Reply #11March 24, 2013, 09:28:27 pm
« Reply #11 on: March 24, 2013, 09:28:27 pm »
#13 - SOLD
« Last Edit: April 13, 2013, 08:20:15 am by 8v-of-fury »
Reply #12November 04, 2013, 08:30:47 pm
« Reply #12 on: November 04, 2013, 08:30:47 pm »
I gots lots, whatta ya neeeeed :) ;D Probably about another 8 full pumps worth of parts not pictured on another shelf!! :P Addiction. Yes.
PM ME FOR MORE DETAILS!! :) :)
Reply #13November 09, 2013, 09:28:36 pm
« Reply #13 on: November 09, 2013, 09:28:36 pm »
TTT
Reply #14November 22, 2013, 09:34:00 am
« Reply #14 on: November 22, 2013, 09:34:00 am »
Top :)
