Author Topic: Coolant Pipe - Turbo to block  (Read 2570 times)
December 13, 2011, 01:38:11 pm
rhwyd
  • 8
« on: December 13, 2011, 01:38:11 pm »
Hi all,
The coolant pipe that connects the turbo to the centre frreeze plug on the block needs replacing - it's corroded badly and is leaking.  The P/N is 068121497A (thanks to Will).  Dealers in NA report it as obsolete.  Does anyone have a used one I can buy?  Are there European sources you can share?
thanks,
doug
1991 Golf CL 1.6L Intercooled TD (SB engine)
Reply #1December 13, 2011, 01:40:35 pm
Re: Coolant Pipe - Turbo to block
« Reply #1 on: December 13, 2011, 01:40:35 pm »
well, soft plugs are pretty much a 1 time use item..
so, i would get the idea out of your head that your gonna get a used one and re-use it..
anyways, i believe that the VR6 uses some kind of soft plug with a nipple on it.. dunno the part number, but i know it exists.
Reply #2December 13, 2011, 02:29:46 pm
rhwyd
  • 8
« Reply #2 on: December 13, 2011, 02:29:46 pm »
Just to be clear - I'm in search of the coolant pipe with the banjo fitting on the end connected to the turbo and a hose clamp connection on the other end.  Preferably new but used in decent shape if necessary
doug
Reply #3December 13, 2011, 02:34:12 pm
« Reply #3 on: December 13, 2011, 02:34:12 pm »
oh, you need the actual coolant line, not the special soft plug..
ok, well, look for a used one, best chances of finding one are from europe, because thats where the engine is native..
thats a RARE engine in North America..
Reply #4December 23, 2011, 08:15:32 am
rhwyd
  • 8
« Reply #4 on: December 23, 2011, 08:15:32 am »
Just to close on this...  The pipe in question became obsolete some time in 2010.  I was able to get the part from an official VW website in Europe.
Volkswagen Classic Parts E-shop (http://www.etkashop.com/vwcp/) has the pipe and many other hard to find parts.
It is, of course, in German but Google translate works wonders.  Once I made e-mail contact the conversation was in English.
doug
