Author Topic: reverse gear keeps poping out.  (Read 5205 times)
December 10, 2011, 11:52:20 am
Grey_Smoke
  • 83
    fling wing for the win.
« on: December 10, 2011, 11:52:20 am »
So after hooking up the transmission linkage None of the gears were lined up with the shifter, so I used the cassette tape trick and lined everything up.  Now all of the gears engage and disengage smoothly.  The only problem is that the transmission keeps coming out of reverse.  reverse will engage and turn the tires, it will even move the car so long as it is on flat ground and the clutch is kept over half way in.  But as soon as the clutch is let out more than half the reverse gear disengages.
I though that maybe the shifter was hitting it's stop before reverse was fully engaged, so I readjusted it, but that didn't change anything.  any help would be appreciated.
thanks.
2001 TDI
86 Jetta Coupe TD - Still going together
sold - the Gutless wonder - 97 AAZ
An Oldvolks Home
Reply #1December 10, 2011, 12:05:16 pm
Re: reverse gear keeps poping out.
« Reply #1 on: December 10, 2011, 12:05:16 pm »
thanks.
every car ive experienced that with, had a worn reverse idler gear.. the gear is worn enough that it pops out of gear.. my GTI used to do that, the first trans i had in there it did it really bad..
CASSETTE TAPE TRICK?!?! i must learn that one.. mind elaborating a bit?
Reply #2December 10, 2011, 12:36:18 pm
Grey_Smoke
  • 83
« Reply #2 on: December 10, 2011, 12:36:18 pm »
the cassette tape trick http://forums.vwvortex.com/showthread.php?2796898
it couldn't just be the shift linkage, could it?
I really don't want to pull the engine and change the transmission, everything worked on the donor car.    :-\
2001 TDI
An Oldvolks Home
Reply #3December 10, 2011, 02:15:38 pm
« Reply #3 on: December 10, 2011, 02:15:38 pm »
It could, but stock linkage is pretty much one way. I have missing linkz kit and it would do that when I didn't have the arm adjusted long enough or the other part on the splines just so.
Reply #4December 10, 2011, 11:51:52 pm
Grey_Smoke
  • 83
« Reply #4 on: December 10, 2011, 11:51:52 pm »
ok thanks, what missing linkz kit/parts do I need, I was looking at their site earlier today and I have no idea where to start.  any suggestions for what is needed, and or suggested?
2001 TDI
An Oldvolks Home
Reply #5December 11, 2011, 02:13:22 am
« Reply #5 on: December 11, 2011, 02:13:22 am »
disconnect linkage at tranny.. put into rev on tranny.. does it work or pop out... if pop out tranny got issue..
Reply #6December 11, 2011, 05:30:25 am
« Reply #6 on: December 11, 2011, 05:30:25 am »
IMO if you go missing linkz go full retard and get the whole kit.
Reply #7December 11, 2011, 09:59:24 am
« Reply #7 on: December 11, 2011, 09:59:24 am »
thats the definitive way to test it.. if the linkage aint hooked up and it pops out, theres problems.
Reply #8December 17, 2011, 03:16:56 pm
Grey_Smoke
  • 83
« Reply #8 on: December 17, 2011, 03:16:56 pm »
so I unhooked the shift linkage and the same thing happened just with out any noise.  does that mean that the reverse gear is shot?
2001 TDI
An Oldvolks Home
Reply #9December 17, 2011, 05:17:23 pm
« Reply #9 on: December 17, 2011, 05:17:23 pm »
I would guess so if it was fully in reverse and still did it.
Reply #10December 17, 2011, 11:08:24 pm
« Reply #10 on: December 17, 2011, 11:08:24 pm »
no linkage eliminates all that.. so yes if it popped out with no linkage.. the gear is damaged.. sorry.. not what you wanna hear..
and parts avaliable at stealership grab your ankles.. after eating lots of fiber.. and hoping to get a kiss afterwards.. like 150 for the small one and the big piece is over 200...
i myself would find a old 4 speed to get the rev gear parts from.. they never seem to wear out.. and most throw them out as they want 5 speeds so value is non existant.. but rev gears same.. :D
Reply #11December 17, 2011, 11:17:24 pm
Grey_Smoke
  • 83
« Reply #11 on: December 17, 2011, 11:17:24 pm »
well we have a grand total of four other mk2 transmissions around here :P so come spring and school letting out for the summer, we will either swap a hole trans or parts from one of them. so after I find out what transmission they are, I will be on here asking which one is the best.  ;D
2001 TDI
An Oldvolks Home
Reply #12December 18, 2011, 05:48:04 am
« Reply #12 on: December 18, 2011, 05:48:04 am »
Brokevw.com in Columbus Ohio rebuilds these trannies. If he has a junk trans he will not mix and match gears to make them work, as he is picky and will only build matched sets. He keeps most all his junk for instances like this were people only need some pieces and don't care if there is a slight gear whine or other things. I know he sold a guy a first gear out of his scrap pile for 10.00 plus shipping, so you maybe close to that.
