Author Topic: Dumba$$ seeks advice-how hard is it to notch pistons?  (Read 4631 times)
December 06, 2011, 12:18:15 am
RustyCaddy
  • 395
« on: December 06, 2011, 12:18:15 am »
i have been dremel-ing an old NA piston that was lying around to see how well it would cut and how accurate i can get using an old turbo piston as a template.
It seems pretty straight-forward but are the kind of small differences that are inevitable with free hand work times 4 pistons going to unbalance the rotating assembly?  If i could notch a new set of NAs that are in the garage (and were cheap) it would save a lot of $$ over true turbo pistons.
None of the shops around here are willing to give it a try.
And the OEM VW turbo piston has some kind of steel band on the inside...are modified NA skirts going to be too weak to trust?
Thanks
Reply #1December 06, 2011, 07:20:53 am
Re: Dumba$$ seeks advice-how hard is it to notch pistons?
« Reply #1 on: December 06, 2011, 07:20:53 am »
it can be done, but the TD pistons are made so they have ALOT less thermal expansion..
you can weigh the pistons on a small parcel scale, or any type of small scale, i would make sure they are all within 1/10th of a gram..
Reply #2December 06, 2011, 09:01:05 am
« Reply #2 on: December 06, 2011, 09:01:05 am »
i believe the td stuff is a different alloy like ror says, could be wrong tho.  and like he says, if u make them all weigh the same when you're done i don't really see what it would hurt assuming u make everything smooth when you're done
Reply #3December 06, 2011, 09:08:59 pm
RustyCaddy
  • 395
« Reply #3 on: December 06, 2011, 09:08:59 pm »
sounds like it is do-able with some practice.
i have been holding onto some 1.5l KS pistons if i get the nerve might give them a try into a MF block with a 1.5 assembly.  Otherwise the 1.6es could go with the turbo crank and rods.
Thanks for the help...
Reply #4December 07, 2011, 03:32:06 am
« Reply #4 on: December 07, 2011, 03:32:06 am »
16+ years ago i had a modded set of na pistons made up for a td... guy used a mill to do a big happy face smile in it.. that engine was still going last i knew 8 years ago... owner finally moved onto tdi.. so will not say its a big differance in alloy.. but it did work.. and was simple..
Reply #5December 07, 2011, 05:44:05 am
« Reply #5 on: December 07, 2011, 05:44:05 am »
the alloys are quite different, not sure of exact names/numbers of the alloys, but there different. the TD pistons even have steel supports cast into the piston, to keep thermal expansion minimal, and strengthen the piston at the same time..
no reason you cant run n/a pistons with oil squirters, because im running n/a pistons WITHOUT oil squirters..
Reply #6December 07, 2011, 06:09:11 am
« Reply #6 on: December 07, 2011, 06:09:11 am »
That seems odd. Steel and Al having different rates of expansion it would seem that a steel ring would be worse than nothing. They would always fight eachother. But I am not a metalurgist and they probably used some super steel with super Al and that is why they are around 100 each for a roughly 3" piston.
Reply #7December 07, 2011, 02:22:10 pm
« Reply #7 on: December 07, 2011, 02:22:10 pm »
That's pretty much it in a nutshell - aluminum expands more than steel, so the steel ring restrains the aluminum, reducing the ACTUAL expansion.  And yeah, they use some pretty nifty alloys and things!!
Reply #8December 07, 2011, 06:14:18 pm
sdwarf36
  • 159
« Reply #8 on: December 07, 2011, 06:14:18 pm »
 A TENTH of a gram??? :o Who told you that?
 We balance race motors all the time at the machine shop I'm at. Road race + Drag stuff that turns up to 9k. A race balance has us to keep the pistons within a gram or 2.  If we told some of our customers "If we balance you motor within a 1/10, it will give you 2 hp---but costs an extra $5k"-they'd do it. And if there was any gain, we'd be doing it.Theres nothing to be gained.
 If you are trying to notch a piston for valve clearance, here is a (fairly )quick + easy way.
Put your pistons in the block-with rings on or tape on 1 skirt (to cut down on rocking).
Take a pair of old  valves-get a piece of tool steel (an old lathe cutter)-and use a die grinder with a cut off wheel to make a piece -maybe a 1/8" wide and length from the center of the valve to about .040 off the valve. Braze the cutter to the valve.
 Put th3 valve in you cylinder head-figure out how much you need to remove from the piston-get a 5/16 drill stop (little collor with a set screw to set depth) + set that distance between the top of the guide + collar.
Put the head on your motor-tighten the head down. (without head dowel pins, alighnment will be tricky.) Chuck the valve in a drill + carefully let it feed down.
 This how it used to be done--and with a little practice, you can get exacting results.
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #9December 07, 2011, 07:05:56 pm
« Reply #9 on: December 07, 2011, 07:05:56 pm »
He's trying to notch pistons for oil squirters not valves.
ROR did you mean tenth of an ounce?
Reply #10December 08, 2011, 07:25:45 am
« Reply #10 on: December 08, 2011, 07:25:45 am »
i measure everything in grams, not ounces.. grams are much more exact. 1/10th of a gram is a much finer measurement than 1/10th of an ounce.
and yes, i know, notching for oil squirters. ive been fully aware since the first post i made.
Reply #11December 08, 2011, 08:19:40 am
sdwarf36
  • 159
« Reply #11 on: December 08, 2011, 08:19:40 am »
Oops! I shoulda known that. :P
Reply #12December 08, 2011, 08:26:17 am
« Reply #12 on: December 08, 2011, 08:26:17 am »
and i know it isnt necessary to balance everything to 1/10th of a gram, but i don it anyways.. ive only balanced my own engines, and i try and MATCH the weights of everything.. not just within a gram or 2.. it usually takes me an extra 20 minutes to match everything, rather than balance things close..
Reply #13December 09, 2011, 07:10:12 pm
RustyCaddy
  • 395
« Reply #13 on: December 09, 2011, 07:10:12 pm »
Thanks again for the help...might have to go to Portland for the mill work afterall.
Reply #14December 09, 2011, 07:13:49 pm
« Reply #14 on: December 09, 2011, 07:13:49 pm »
send them to me, i will do it for you..
