Author Topic: weird oil pressure behaviour  (Read 4083 times)
November 22, 2011, 08:59:03 am
bgrunhaus
  • 8
« on: November 22, 2011, 08:59:03 am »
Hey  guys!
I have a AAZ 1.9td with weird oil pressure behaviour(as the title states)
look at this video and give me your opinion! http://www.youtube.com/watch?v=mnBFCTRYAuQ
after warmup it idles at 40psi, if i rev it a few times the pressure rises and the start dropping....
turn of the engine, restart and 40psi again! what is going on?????
please help me out!
Reply #1November 22, 2011, 12:39:51 pm
guy plain
  • 121
Re: weird oil pressure behaviour
« Reply #1 on: November 22, 2011, 12:39:51 pm »
when is the last time you did a oil/filter change?
Reply #2November 22, 2011, 01:27:59 pm
maxfax
  • 2126
« Reply #2 on: November 22, 2011, 01:27:59 pm »
That, and was it something that started all at once, or gradually?
Reply #3November 22, 2011, 05:57:48 pm
bgrunhaus
  • 8
« Reply #3 on: November 22, 2011, 05:57:48 pm »
i had some issues with th vacuum pump but already fixed that!
after i bit of idling the pressure is now bullet proof! also found out that the previous owner messed with the oil pressure relife valve so im hitting over 100psi@ startup!
thank you guys for the answers!
ill be changing oil tomorrow!
 :D x 1.000.000
Reply #4November 22, 2011, 06:02:22 pm
« Reply #4 on: November 22, 2011, 06:02:22 pm »
 :D x 1.000.000
completely normal..
Reply #5November 22, 2011, 06:22:05 pm
« Reply #5 on: November 22, 2011, 06:22:05 pm »
I hit 100 psi all the time at cold idle start up.  Once it warms it drops to 80, start driving and the standard cruising pressure is 65 to 70.  After a couple of hours on the road it will drop to 40 as I pull into the rest area.
Was the issue with the vac pump or the seal that goes on it?
Reply #6November 24, 2011, 03:30:07 pm
stewardc
« Reply #6 on: November 24, 2011, 03:30:07 pm »
What has always amazed me is that these engines can see 80 psi cold but only give 15-20 psi warm.
Reply #7November 24, 2011, 09:28:08 pm
damac
  • 531
« Reply #7 on: November 24, 2011, 09:28:08 pm »
curious, what is the oil pressure relief valve and where is it on my 85 jetta td?
1985 turbo diesel jetta
Reply #8November 25, 2011, 06:28:10 am
« Reply #8 on: November 25, 2011, 06:28:10 am »
I do believe it is part of the oil filter mount? I could be wrong.
Reply #9November 25, 2011, 09:12:23 am
Mark(The Miser)UK
  • 1557
« Reply #9 on: November 25, 2011, 09:12:23 am »
I think you'll find it's on the oil pump, and is a piston tube with a crimped end for unservicability purposes, or am I thinking of my old Bedford. ;D
Mark-The-Miser-UK
Reply #10November 25, 2011, 09:25:49 am
guy plain
  • 121
« Reply #10 on: November 25, 2011, 09:25:49 am »
 a Bedford? now thats showing your age ! lol i have,nt seen one of those in Canada for alot of years (ooops just showed my age as well)
Reply #11November 25, 2011, 12:23:35 pm
« Reply #11 on: November 25, 2011, 12:23:35 pm »
its crimped shut.
Reply #12November 25, 2011, 12:42:57 pm
damac
  • 531
« Reply #12 on: November 25, 2011, 12:42:57 pm »
Just curious if there is wear on the oil pumps that results in less oil pressure over time.  (assuming of course the pump and vacuum pump are indexed ok and not slipping)
When I got my jetta I cleaned out the pump of rtv and intermediate bearings which I replaced.  I am borderline bently spec which kind of scares me, but I have a manual gage I keep my eye on and pressure increase with the pedal.
I didn't know any better at the time so I just cleaned and reinstalled, but replacing those bearings didn't help oil pressure for me.
I wonder if its possible my 85 jetta td came with the 30mm pump.  If I were to upgrade to 36mm pump anybody got any specific changes in pressures after making the change?
I would just go yank the pan, problem is I sealed it with right stuff last time because it was leaking when I got it.  No leaks now but I have no idea how to get it off :(
Reply #13November 25, 2011, 07:31:41 pm
bgrunhaus
  • 8
« Reply #13 on: November 25, 2011, 07:31:41 pm »
the issue with the vacuum pump was excesive wear in the rotor.
the pump wasnt installed right onces and the oil pump shaft was pushing the rotor against the pump cap and started grinding the rotor and with time i lost around 1/4" from the rotor!
a friend that has a lathe fixed the pump!
now the vacuum pump drives the oil pump flawlessly!
as for the high pressure i wont worry anymore! thanks for that!
it would be nice installing a bigger pump in the car! i think that hydraulic heads already have large oil pumps!
thank you all for your input!
