VWDiesel Blog
Facebook Group
VWD on Twitter
General Information
Upgrades (non engine related )
Quick weatherstrip alternative question
Topic: Quick weatherstrip alternative question (Read 2411 times)
November 10, 2011, 07:12:06 pm
camboscams
November 10, 2011, 07:12:06 pm »
So would something like this work in our MK1's. I can't find anything to replace whats there but im wondering if this would work on the car side right on the pinch welded opening.
Just search this number 1120A391 on
Mcmaster.com
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
November 10, 2011, 07:23:43 pm
camboscams
Re: Quick weatherstrip alternative question
November 10, 2011, 07:23:43 pm »
The bulb would face outwards. but the more i look at it maybe the bulb should be a little bit bigger.
November 10, 2011, 10:18:11 pm
November 10, 2011, 10:18:11 pm »
Mounted on the car side I'm not sure what part of the door would seal on it.......I'd really like to have new seals too.
November 10, 2011, 10:32:44 pm
camboscams
November 10, 2011, 10:32:44 pm »
So where the factory edge grip seal is over the pinch weld in the door opening on the body of the car. The black stuff on each side of where the upper mounting point for the seatbelt. It would seal on the inner facing side of the door.
November 12, 2011, 07:37:18 pm
GEE-BEE
November 12, 2011, 07:37:18 pm »
Iam running 5000 ft of upper door seal
original mk1 design
GB
[email protected]
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
November 13, 2011, 08:52:31 am
camboscams
November 13, 2011, 08:52:31 am »
So your making weather strip that is right above the window where it seals on the body? just the short section on the horizontal part of the door?
November 13, 2011, 10:50:31 am
GEE-BEE
November 13, 2011, 10:50:31 am »
you are correct from the original design
I make all the seals for MK1autohaus & silicone hoses for the mk1 & mkII
Vanagon diesel and synros for vancafe
GB
Giles Pump OHC
MK1 JETTA DASH
General Information
