Author Topic: giles rebuilt my vanagon IP  (Read 11130 times)
Reply #15December 18, 2011, 11:29:41 pm
Toby
  • 728
Re: giles rebuilt my vanagon IP
« Reply #15 on: December 18, 2011, 11:29:41 pm »
400 psi 2 years ago does not mean squat today. Run a compression check.
BTW just what do you think so called "pimping you GPs" is going to do for you? It won't make you motor start better. It won't make it run better. It might make it easier to troubleshoot a bad GP, but so what? Everything I drive is diesel and I only have to replace one a year or so. BTW Schmucks cheap ass wire with crimp on connectors is not going to conduct as much as that solid copper buss bar you guys seem to hate so much.
It is MUCH easier to check glow plugs with an ammeter. You don't even have to get dirty.
Reply #16December 19, 2011, 05:25:47 am
motomike33y
  • 190
« Reply #16 on: December 19, 2011, 05:25:47 am »
didn't get finished.  compression is 520, 600, 540, and 450.  I like controlling the glow plugs because it used to have a hot start problem unless I used the glow-plugs.  You may be right about the copper bar, but my other vehicle w/individual wiring starts much better than before. Timing seems to be spot on between TDC, my flywheel notch, the cam holder, and IP gear pin.  probably no time now until next weekend
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress           suzuki samurai hardtop that may someday be diesel
2012 golf tdi
Reply #17December 19, 2011, 05:56:02 pm
damac
  • 531
« Reply #17 on: December 19, 2011, 05:56:02 pm »
My old f250 has basic spade connectors and it seems to do fine.  I got a push button on it as well to stop people from driving it and to prevent potential glowplug controllers sticking.  Don't have a problem with it, 10 seconds and I'm off.  None needed when block is hot.
I have been lucky with my diesels thus far and never needed to use glowplugs when the block is hot, like say a quick stop in the store during winter.  In summer I can let them sit for a while and come out and start them right up with no glowplugs due to heat soak I suppose?
When I last replaced my injection pump on the truck I found out the hard way that at its hottest the truck wouldn't restart.  If I was lucky I could run around and jump in and get it started.  But then I got stuck a few times when shopping for 20 minutes and I think the ip got even hotter due to heat soak and I was stuck over an hour.  Got stuck a few times before getting another pump, that sucked :)
Do our vw 1.6 pumps suffer from heat soak?
1985 turbo diesel jetta
Reply #18December 19, 2011, 08:07:01 pm
« Reply #18 on: December 19, 2011, 08:07:01 pm »
Heat soak, or hard hot starting is caused by a worn head and rotor. It is reasonably common on the pumps on the 6.2s, 6.5s, 6.9s and 7.3s. I think those were all DB pumps... it's been too long though.
Reply #19December 28, 2011, 05:17:53 pm
motomike33y
  • 190
« Reply #19 on: December 28, 2011, 05:17:53 pm »
got the new wiring done for the glow plugs, spun the engine a bit to get fuel to the injectors, tightened the nuts, glowed for 10 seconds, and it started right up-temp in 30s then.  today in 20's after night in the teens, glowed for 10 seconds and it fired right up.  had to restart a couple times till things got warmed, but starting problem apparently with the glow plug circuit.  have to get my switches finished up then try some driving to compare the new IP
2012 golf tdi
Reply #20January 07, 2012, 02:03:44 pm
Toby
  • 728
« Reply #20 on: January 07, 2012, 02:03:44 pm »
450 to 600 is quite a spread. 25% difference is way to high. Did you do it hot, with a good battery and a big charger hooked up?
Reply #21January 07, 2012, 03:05:23 pm
somolovitch3
  • 290
« Reply #21 on: January 07, 2012, 03:05:23 pm »
to high?
8 ga wire from 40 amp relay, (one per glow plug), crimmped and sweated ring terminals.
MUCH easier to change one glow plug, not to mention, Confuses the flip out of folks when they see what lives in my rain tray.
I would love to know how one gets 600 on a cylinder, I am lucky to get 425! Majic, no? :o
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #22January 07, 2012, 04:05:56 pm
Toby
  • 728
« Reply #22 on: January 07, 2012, 04:05:56 pm »
Yeah it may save you 5 or six minutes.
Reply #23January 07, 2012, 04:44:21 pm
« Reply #23 on: January 07, 2012, 04:44:21 pm »
600 psi sounds like something is coating the piston or valves and that is not a good sign.  The spread here is too big as well.
I just came in from doing the compression check on my 1.6.  I thought I had one that was worse than the others but as it turns out all 4 are right at 480.  Love that.  I was expecting to be low by more than 71 psi on one along the line.  I just felt loose as I turn it over by hand.
Have you checked the valve clearance lately?  That is the Bentley suggestion
Something is not right on those readings.
Reply #24January 08, 2012, 02:15:29 pm
Luckypabst
  • 502
« Reply #24 on: January 08, 2012, 02:15:29 pm »
 With the stock wiring, the glow plug current path is up to the ignition switch and back to the relay, then to the plugs.  On a vanagon, that's an extra 25 feet of wire and connections that can get corroded.
Not exactly. The low current side of the glow plug relay is run through the ignition switch. The high current side, which sends power to the plugs, is kept within the engine bay.
Excessive resistance on the low current side isn't much of a concern in all but extreme cases.
Chris
« Last Edit: January 08, 2012, 02:27:42 pm by Luckypabst »
'82 TD Westy
'81 NA Caddy
Reply #25January 08, 2012, 03:29:26 pm
motomike33y
  • 190
« Reply #25 on: January 08, 2012, 03:29:26 pm »
for whatever the reason, after my rewiring the glowplugs and cutting out the relay,it starts easily now.  I started driving it this weekend while I work on my tdi.  noticed the power with the rebuilt pump as it accelerates more quickly(altho still a slug) and cruises at 55 easily w/throttle left.  I've only put about 40 miles on set-up so I'll see how things go.  I know difference is over 25% between cylinders, but I'm used to my rabbits having a hard time getting 300 psi, so I'm not going to worry too much at this point
2012 golf tdi
Reply #26January 17, 2012, 01:01:41 pm
motomike33y
  • 190
« Reply #26 on: January 17, 2012, 01:01:41 pm »
drove it a couple hundred miles during the past couple weeks.  other than someone stealing my radio, I've been very pleased.  timing is still a bit advanced from the sound, but it started right up even in temps in the teens(fahrenheit), and pulled strongly on the highway.  several hills that normally would slow me, I now can accellerate from 40mph in 4th as I go up the hill.  cruises easily at 60 on the expressway and gets there quicker in 3rd and 4th.  put my first tank of fuel thru and only got 23mpg so wondering if that's normal-used to get 25-30 but for warmer weather and longer drives.  still happy but need to try to get a lock for my door before I put another radio in
2012 golf tdi
Reply #27January 17, 2012, 07:38:47 pm
« Reply #27 on: January 17, 2012, 07:38:47 pm »
Is this the 1.9 w/ 1.6 head?
Overly advanced timing can easily take a toll on mpg. I'd fiddle with it and try and at least get the same numbers you were getting in the summer.
Reply #28January 19, 2012, 09:45:20 am
motomike33y
  • 190
« Reply #28 on: January 19, 2012, 09:45:20 am »
thanks-probably this weekend.  think I need a new solenoid for my glow plugs as I forgot and left the switch on for a couple miles of driving last nite, now won't start this morn as solenoid won't work.  had been going to do toggle switch that automatically went to off but couldn't find one.  this reinforced my need for one.
2012 golf tdi
Reply #29January 19, 2012, 03:01:28 pm
« Reply #29 on: January 19, 2012, 03:01:28 pm »
When I have had solenoids stick I tap them on the side with a wrench or something solid.  Never had one not come back.  Did you arc the contacts together?
Leaving it on for a couple minutes, I wouldn't think it would do that.  Get a hammer on it.
I take it you ran one non pushbutton switch to the relay on the low current side.
