Author Topic: Need some advice or opinions  (Read 3508 times)
November 06, 2011, 02:04:20 pm
chopper03
  • 42
« on: November 06, 2011, 02:04:20 pm »
I have got a 1z tdi motor from a 96 Passat with the 5 spd cable shift trans.
 I want to put in my 82 Caddy truck.
 I also have a 12mm bosch mechanical idi injection pump that i would like to use.
 Can anyone tell me which injector nozzles and turbo I would need to use for the best
performance with the 12mm pump.
Or will this pump even work as is, Or do I need to install the tdi camplate ?
Reply #1November 06, 2011, 08:11:49 pm
410
  • 581
Re: Need some advice or opinions
« Reply #1 on: November 06, 2011, 08:11:49 pm »
What did the idi 12mm pump come from?  Was it a stationary/industrial engine?  If so the camplate isn't the only thing you need to worry about.  You'll need to look at the advance curve and the governor as well.
Reply #2November 07, 2011, 02:06:52 am
chopper03
  • 42
« Reply #2 on: November 07, 2011, 02:06:52 am »
I don't really know, I bought it from e-bay its new bosch I looked the numbers up and
it says hercules 4 cylinder 2400 rpm. I will get the number from the pump ans
post it tonight.
Reply #3November 07, 2011, 10:17:30 am
410
  • 581
« Reply #3 on: November 07, 2011, 10:17:30 am »
Would you be able to post a picture of the pump?
Reply #4November 07, 2011, 05:00:14 pm
chopper03
  • 42
« Reply #4 on: November 07, 2011, 05:00:14 pm »
pictures of pump
now lets see if this works
