Author Topic: Piss, got the head on and motor running...noticed a problem...  (Read 4166 times)
October 22, 2011, 04:22:10 pm
vdubspeed
  • 191
« on: October 22, 2011, 04:22:10 pm »
So I bought an 89 NA Jetta with a snapped t-belt. Slapped it all backed together and tonight it fired up AWESOME. Then I noticed something....the lip on the intermediate shaft that is on the tb cover side is gone. I checked my other diesel engine blocks and sure enough...big fat lips.
So...do I suck it up and replace it or will the t-belt track straight without the lip.
Thanks,
Jason
P.S...if I do replace it...are they a PITA to get off while in car?
Reply #1October 22, 2011, 04:32:24 pm
vdubspeed
  • 191
Re: Piss, got the head on and motor running...noticed a problem...
« Reply #1 on: October 22, 2011, 04:32:24 pm »
Might have jumped the gun. Seems as if there are two pulley styles. Early ones with lip and later ones without the lip. Hmmmm...I just don't want to f up this awesome running franken diesel engine.
Reply #2October 22, 2011, 04:37:12 pm
« Reply #2 on: October 22, 2011, 04:37:12 pm »
yea, the later engines got a smooth IM shaft pulley.
i imagine its so that if the belt isnt tracking perfect, then that lip on the pulley wont chew it up..
because if the belt is walking off the injection pump, then the IM shaft pulley is going to be the next place the belt runs, and if its not entering the pulley straight, then its going to chew up the belt, from running on the lip..
Reply #3October 22, 2011, 04:41:04 pm
vdubspeed
  • 191
« Reply #3 on: October 22, 2011, 04:41:04 pm »
Thanks for the reassurance friend. That makes me feel good now.
This puppy fired up third crank and I has been a MASSIVE learning experience over the last three weeks. 89 hydro block, 85 turbo diesel mech head, an old rabbit diesel cam, head resurfaced, pc cups peened, block tapped and plugged, head tapped and plugged, etc, etc, etc. Just glad to hear it ROAR to life ;D
Reply #4October 22, 2011, 08:07:54 pm
« Reply #4 on: October 22, 2011, 08:07:54 pm »
if the lip is damaged.. stop.. it will cut the belt..
now buy new.. NO F IN WAY...
pull the pully off.. goto a local brake shop.. with case of beer.. ask the guy really nicely.. do you have a adapter for a old say beetle brake drumb.. really thin.. fits right thru the hole of pully..and use brake lathe to remove it... :D 2-3 min of work you will have late model looking pully..
yep done that a few times...
Reply #5October 23, 2011, 05:38:25 am
vdubspeed
  • 191
« Reply #5 on: October 23, 2011, 05:38:25 am »
the lip is not damaged...it's just not there. I'm used to working on mk1 diesels and their intermediate pulley's have lips. I found that starting with the mk2's, VW went to pulley without a lip.
Should have never made a post. Pretty soon I'm sure I'm going to be told to rebuild the motor.
Reply #6October 23, 2011, 11:43:28 am
« Reply #6 on: October 23, 2011, 11:43:28 am »
actually 89/90 started no lip ones... had tons of screwed up lip ones that got modded after that.. :D how i know brake lath trick.. took old kept for scrap aluminum and converted them into on shelf for older ones..
Reply #7October 23, 2011, 02:08:33 pm
regcheeseman
  • 714
« Reply #7 on: October 23, 2011, 02:08:33 pm »
Intermediate shaft with a lip? Never seen one.
Ignore it, I'm more interested in the setup of the elusive 'perfect running' Franken - is it a 16/19?
Reply #8October 23, 2011, 02:40:45 pm
« Reply #8 on: October 23, 2011, 02:40:45 pm »
With how old this stuff is nothing is factory anymore. My '82 rabbit: no lip......'92 golf: has lip. I think somebody messed with both.
Reply #9October 23, 2011, 02:49:55 pm
« Reply #9 on: October 23, 2011, 02:49:55 pm »
ALL of my engines have a lip on the IM shaft pulley.. but ive seen both kinds on both early and late engines..
its kinda funny, gassers got an IM shaft SPROCKET (runs on the cogged side of the belt)
and the diesel got an IM shaft PULLEY.. (runs on the smooth back side of the belt)
ive experienced first hand, as to why they removed the lip.. i had a bad bushing on my first diesel, and the belt walked off the IP about a 1/4", then the IM pulley started eating the belt. i cant believe how long i ran it with a chewed up belt.. thinking back on it, it kinda makes me sick.. atleast i changed the belt before it snapped..
Reply #10October 23, 2011, 04:34:36 pm
« Reply #10 on: October 23, 2011, 04:34:36 pm »
The gasser has to keep the distributor in time while the vac pump on a diesel doesn't matter...... ;D
Reply #11October 23, 2011, 06:33:33 pm
« Reply #11 on: October 23, 2011, 06:33:33 pm »
even the early ones have a variety of styles, not that its really anything to discus, they all do the same thing
Reply #12October 24, 2011, 06:09:10 pm
vdubspeed
  • 191
« Reply #12 on: October 24, 2011, 06:09:10 pm »
Don't know what you mean by 16/19 but this motor runs like a dream.
Reply #13October 24, 2011, 07:33:02 pm
« Reply #13 on: October 24, 2011, 07:33:02 pm »
He's talkin' about a 1.6 block and a 1.9 head.
Reply #14October 25, 2011, 03:08:49 am
vdubspeed
  • 191
« Reply #14 on: October 25, 2011, 03:08:49 am »
Na...nothing like that. Just a motor built from the pieces of many other motors.
