Author Topic: installing mechinical head on Hydraulic block for a vanagon  (Read 5501 times)
October 18, 2011, 01:58:11 pm
rsvp
  • 21
« on: October 18, 2011, 01:58:11 pm »
HI All,
What do I need to do to install my mecanical head on a later (hydraulic) block?
which head gasket should I use?
thanks!
Reply #1October 19, 2011, 08:14:42 am
Re: installing mechinical head on Hydraulic block for a vanagon
« Reply #1 on: October 19, 2011, 08:14:42 am »
usually, people put a hydro head on a mechanical block..
Reply #2October 19, 2011, 09:23:03 pm
maxfax
  • 2126
« Reply #2 on: October 19, 2011, 09:23:03 pm »
IIRC  there is a coolant passage in the head that lines up pretty darned good with that second oil drain.. You'll need to plug that second oil drain in the block..  Tap it for a pipe plug and screw it in there flush with some sealer..  It would be best to have your oil pan removed so that you can flush all the cuttings from the tap outta there..
Next you'll need to contend with the coolant passage in the head.. Use the Hydro gasket with something cut out to fit in the hole for the extra oil drain to seal things up.. A piece of gasket or rubber about the same thickness would do..  A little hylomar sealer around the whole mess wouldn't hurt either..
*EDIT* You could probably use the mech gasket as well, but once again the little hole for the coolant would need plugged somehow...
« Last Edit: October 19, 2011, 09:50:33 pm by maxfax »
Reply #3November 03, 2011, 05:16:16 pm
rsvp
  • 21
« Reply #3 on: November 03, 2011, 05:16:16 pm »
HI All,
I went with the  Hydraulic head and rebuilt it myself...I had it, it just was not rebuilt.
 Thanks for the help and thoughts! :)
regards,
Steve
