Author Topic: SHCS for 11mm Head bolts?  (Read 4730 times)
Reply #15November 02, 2011, 12:06:03 pm
Re: SHCS for 11mm Head bolts?
« Reply #15 on: November 02, 2011, 12:06:03 pm »
very veeird...
all the blocks ive blown to pieces, were all # 9 and #10 head bolt holes to get the worst cracks..
Reply #16November 03, 2011, 04:52:26 am
maxfax
  • 2126
« Reply #16 on: November 03, 2011, 04:52:26 am »
If you compare the 11mm and 12mm block side by side, the 12mm is thicker in those areas..   I have to wonder if maybe the alloy wasn't improved too.. After all the 11mm engines were the first shot at a diesel. And basically they are based on a (zipping up the flame suit) gasser block..
That block I welded only had 2 holes that weren't cracked..   :o
