Author Topic: Next, I will start building the mount  (Read 24771 times)
Reply #45November 27, 2011, 02:19:00 pm
Re: Next, I will start building the mount
« Reply #45 on: November 27, 2011, 02:19:00 pm »
KEv, your logic is Whacktastic :) lol
Reply #46November 27, 2011, 02:31:41 pm
« Reply #46 on: November 27, 2011, 02:31:41 pm »
im not sure if thats a good or bad thing?
Reply #47November 27, 2011, 02:37:22 pm
« Reply #47 on: November 27, 2011, 02:37:22 pm »
always good tiko-brohey.
Reply #48December 17, 2011, 01:27:51 pm
« Reply #48 on: December 17, 2011, 01:27:51 pm »
Well I have the mount made. I did do the underside gusseting I was planning on. If you are interested I am going to be sending a couple off for testing shortly and once I hear how they fit up on car I will sell them to whoever I want to. Price is going to start off at 75.00 plus shipping. It will come with all the hardware to fasten it on the engine mount and block.
I stated testing on car as I know they will bolt to the block and to the mount. It is very tight as the holes are pretty picky but they all test and fit. What I am really looking at the test for is the half shafts. I don't have spare car to bolt all this up to to see if anything hits. I figure that it won't as I took many measurements off the cast stock one, but lowered cars and real world will be the actual test I guess.
Also, if I forget to tell whoever wants one, for whatever reason it goes on easier if you start with the top left bolt to the block if you are behind the engine looking at it. If you start it first it goes on like butter, if you start any of the others it is a pain, but you can still get it.
Reply #49December 18, 2011, 01:19:40 am
carrizog60
  • 978
« Reply #49 on: December 18, 2011, 01:19:40 am »
hi
just to share that on my 1.9 passat the turbo fitted fine.
1.9d intake manifold and gt2052v welded to a 1.6gtd exhaust manifold(it will it the firewall no matter what)
just had to angle skim  both manifolds on the side they attached to the engine to put the two a bit higher.
Portugal
Reply #50December 18, 2011, 05:56:12 am
« Reply #50 on: December 18, 2011, 05:56:12 am »
Great job.
This mount is for people that have the vnt1749v, 1749va, 1749vb turbos and don't want to weld it to a manifold. I think if I wanted to use the same intake I have now, but I don't :D
Reply #51December 18, 2011, 01:50:21 pm
carrizog60
  • 978
« Reply #51 on: December 18, 2011, 01:50:21 pm »
thanks.
why not to use the 1Y intake?
with minor mods(reverse the opening side) works great.
at least better than stock TD ones...
Portugal
Reply #52December 18, 2011, 03:21:41 pm
« Reply #52 on: December 18, 2011, 03:21:41 pm »
thanks.
cause if your turbo is high mounted like lucas's is, it doesnt work out.. the 1Y wont fit with a high mounted turbo, only a flipped manifold, custom manifold, or VNT will clear a 1Y manifold..
Reply #53December 18, 2011, 04:33:21 pm
« Reply #53 on: December 18, 2011, 04:33:21 pm »
I have a manifold from Finland that AKI 76 built. It will go on as soon as I make the VNT controller and hang the turbo...which will be pointed down. FWIW I also have a CIS gasser intake still on a 1.8
Reply #54December 18, 2011, 04:53:45 pm
« Reply #54 on: December 18, 2011, 04:53:45 pm »
once you VNT it, you will want to use the 1.8 manifold..
you still running a full 1.6 arent you?
Reply #55December 19, 2011, 05:58:37 am
« Reply #55 on: December 19, 2011, 05:58:37 am »
Seen below
Reply #56December 19, 2011, 08:45:06 am
« Reply #56 on: December 19, 2011, 08:45:06 am »
lmfao..
guess i was having a dirka-dirka moment there..
obviously you will wanna use the Aki manifold..
im going to build one similar, out of a CIS 1.8 intake..
i dont have the balls to cut up my 5 cylinder intake manifold..
Reply #57December 19, 2011, 11:47:33 am
« Reply #57 on: December 19, 2011, 11:47:33 am »
Is there a lip on that intake manifold for the boost tubing to hold onto?
Reply #58December 19, 2011, 01:36:03 pm
« Reply #58 on: December 19, 2011, 01:36:03 pm »
it appears that there is something machined into the inlet to hold the hose. if you hook a boost hose to a non-lipped tube, it just blows off.
Reply #59December 19, 2011, 04:32:33 pm
« Reply #59 on: December 19, 2011, 04:32:33 pm »
yeah there are 2 machined groves in the end. I have some really good T bolt clamps that hold well. I have my t bolt clamps that are holding my tubing now and they are doing great. I do have them buried into the next tube inside the coupler.
The big pain will be making the controller to go around that intake.
