Author Topic: HELP! timing issues.....  (Read 5218 times)
Reply #15October 10, 2011, 01:03:08 pm
  • 4553
Re: HELP! timing issues.....
« Reply #15 on: October 10, 2011, 01:03:08 pm »
Credit goes to Vanagonturbo  Ding Ding Ding ding ding.
Reply #16October 10, 2011, 01:33:21 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #16 on: October 10, 2011, 01:33:21 pm »
[takes bow] :)
Reply #17October 11, 2011, 03:28:28 am
Mark(The Miser)UK
  • 1557
« Reply #17 on: October 11, 2011, 03:28:28 am »
What was the state of the gasket?
Did it just drop off loose, or did you need to scrape it off.
If loose and uncorroded, I'd be tempted to reuse, as it is a 'perfect' fit and should locate.
Treat like a metal gasket  as less compressible, bolts to spec, or 95 lbft if stretch.
That way you have a spare gasket if needed.
Mark-The-Miser-UK
Reply #18October 11, 2011, 05:46:17 am
92EcoDiesel Jetta
« Reply #18 on: October 11, 2011, 05:46:17 am »
Interesting. Have you succesfully re-used a fiber head gasket?
Reply #19October 11, 2011, 07:39:36 pm
Mark(The Miser)UK
  • 1557
« Reply #19 on: October 11, 2011, 07:39:36 pm »
Yes. In fact it's the current one on my Quantum
I reused it after my rering last August [2009]. I did have a new one to hand, but as it hadn't leaked since I put it in a few years earlier after I skimmed the head, after the old gasket had failed; I decided to try it.
If not stuck down, it locates perfectly due to the uncompressed 'exposed' parts of the gasket
Mark-The-Miser-UK
Reply #20October 12, 2011, 02:01:15 am
monomer
  • 414
« Reply #20 on: October 12, 2011, 02:01:15 am »
Gaskets in ok shape.
It did fall off without scraping. I'm not going to risk it going as the gasket is rather cheap. I'm also using my set of cosworth head studs I bought awhile ago, as I don't want to reuse them either.
Car's going back together and looking good. Just connect all the driveline and linkages.
www.michiganvw.org
