Author Topic: aaz with a 92 tach reading to high  (Read 7393 times)
September 15, 2011, 04:40:21 pm
colhel59
  • 34
« on: September 15, 2011, 04:40:21 pm »
i swapped a aaz in to my 92 gti i also changed the cluster to work with the diesel. But its reading to high, iv read that you can change a resistor and wat not to make it read properly. But all the pics i see are totaly diffrent from the back of my tach can some one help me.
Uploaded with ImageShack.us
hopefully this pic works  ;D
thanks for the help
« Last Edit: September 15, 2011, 08:10:58 pm by colhel59 »
Reply #1September 15, 2011, 08:41:37 pm
Re: aaz with a 92 tach reading to high
« Reply #1 on: September 15, 2011, 08:41:37 pm »
what alt set up?? serp? stock?
Reply #2September 15, 2011, 08:54:35 pm
colhel59
  • 34
« Reply #2 on: September 15, 2011, 08:54:35 pm »
its the serp setup
Reply #3September 16, 2011, 06:13:44 am
« Reply #3 on: September 16, 2011, 06:13:44 am »
ok... i bet no ac too...
what ive found is due to removing the ac out of it, running a smaller belt.. the alt spins faster..
this is why the tach is off.. say close to 2k at idle??
how to fix.. no idea.. dakota digital thinggy?? i have same issue on my toaster with its tach.. and mykes tdi coupe does too..
so interested in how you fix!! sadly i am no help.. but if your getting around 2k with no ac thats why..
also never seen a tach set up like that.. got maf built into it by chance??
Reply #4September 16, 2011, 06:37:21 am
colhel59
  • 34
« Reply #4 on: September 16, 2011, 06:37:21 am »
its say 1500 at an idle. doesnt make sence to me about no ac because the belt may get shorter but the pully size doesnt change which is was give you ur ratio the alt spins at compared to the crank pully. I seen some kind of potentoimeter on the tach also on is in the bottem left corner by my finger and one is right beside the large capasitator. sorry about my bad spelling i guess thats why i never became an english teacher lol
Thanks Colton
Reply #5September 16, 2011, 07:28:08 am
92EcoDiesel Jetta
« Reply #5 on: September 16, 2011, 07:28:08 am »
You have nothing to lose by marking the potentionmeter and adjusting it and see if it is an adjustment for the tach.
Reply #6September 16, 2011, 09:24:44 am
« Reply #6 on: September 16, 2011, 09:24:44 am »
if the big pulley, and small pulley dont change size, then how does the alternator spin faster?
doesnt make sense..
the alt should be turning the same speed weither the belt is 5" long, or 5 feet long, or 5 miles long for that matter..
i dont get it??
Reply #7September 16, 2011, 04:12:58 pm
« Reply #7 on: September 16, 2011, 04:12:58 pm »
Here's a literal pro tip. Use a plastic or wooden something something to adjust it. Although I doubt this is the case, there are adjustments in some sensitive electronic circuits that should be made with a non-ferrous tool, because the adjustable component is small and delicate, and therefore affected by magnetic fields.
Reply #8September 17, 2011, 01:44:37 am
carrizog60
  • 978
« Reply #8 on: September 17, 2011, 01:44:37 am »
on my passat i have the same issue.
1.9 engine with serpentine setup and i guess a 1.6 tacho.
try to get a different pulley for the alternator,someone told me one time that citroen 1.9td alt pulley solved the problem.
Portugal
Reply #9September 17, 2011, 08:14:11 pm
  • 2932
« Reply #9 on: September 17, 2011, 08:14:11 pm »
The Mk2 tachs have a potentiometer that can be adjusted, most likely the one by your thumb.
 Hard to adjust because you have to remove the cluster/adjust/replace/ test,.. repeat.
 I moved one outside the cluster on one,.. it was hanging off to the side so I could adjust it with it in the car and running.
« Last Edit: September 17, 2011, 08:17:09 pm by fatmobile »
Reply #10September 18, 2011, 01:44:11 am
carrizog60
  • 978
« Reply #10 on: September 18, 2011, 01:44:11 am »
does the passat clusters are adjustable too?
Portugal
Reply #11September 19, 2011, 05:09:56 pm
colhel59
  • 34
« Reply #11 on: September 19, 2011, 05:09:56 pm »
adjusting the bottom left potentiometer brought my rpm down its still slightly high a but its a hell of alot closer now. thinking about putting my own potentiometer in places of the original.
thanks for the advice
Colton
Reply #12September 20, 2011, 05:51:41 am
regcheeseman
  • 714
« Reply #12 on: September 20, 2011, 05:51:41 am »
You can try but in my experience the chip (SAK215) can't cope with such a short sample cycle and just shuts down when you start to rev the engine - it'll recover though, so no harm done.
they are.
Reply #13September 20, 2011, 06:17:01 am
nathan_b
  • 361
« Reply #13 on: September 20, 2011, 06:17:01 am »
doesnt make sense..
i dont get it??
Yet it still does it, every time.....
Reply #14September 20, 2011, 08:21:34 am
92EcoDiesel Jetta
« Reply #14 on: September 20, 2011, 08:21:34 am »
doesnt make sense..
i dont get it??
You don't get it? All you have to change is the size of one pulley to change the RPM of the alternator. On an AC less system, I assume the alternator is driven off the harmonic balancer pulley (crankshaft) and I assume the harmonic balancer pulley is a different diameter pulley (bigger) than the AC pulley to cause the tach to read higher.
You can fix your tach by doing what I did on mmy 92 Eco, which didn't come with a tach. This thread http://www.vwdiesel.net/forum/index.php?topic=20437.0 documents my journey in putting a working tach in it. I started with a Mercedes tach, then a Peugeot tach, then finally a VW gasser CE2 tach/cluster driven by a sensor off of the crankshaft. My tach aslo use the SAK215 chip so it can be done with some modification and calibration. The title of "a real tach" was I have never seen a tach driven from a signal from an alternator on a diesel before (I think only VW does it), which causes tach to be off when you change pulley size. The crankshaft is really the best place to get the signal for the tach, it is not affected by pulley size changes.
