Will a 1.6 td exhaust down pipe of a 1991 Jetta work on my 1981 Rabbit truck. I have heard there may be some clearence problems with the shift linkage. Can the pipe be mod. to work?
not even CLOSE to fitting.. you would have to hack it up soo bad that it wouldnt even be worth it..
the steering rack is mounted to the BODY on your car..
the steering rack is mounted to the SUB FRAME on the mk2 car you want parts off of.
it clears the shift linkage just fine, just wont clear anything else
wait, turbo downpipe, or exhaust downpipe? there IS a difference.
turbo downpipe is cast iron, bolts directly to turbo.
exhaust downpipe is steel tubing, and connects to the turbo downpipe with some BIG c clips.
