Author Topic: need verification about replacing cam  (Read 5441 times)
Reply #15September 12, 2011, 08:10:04 pm
Re: need verification about replacing cam
« Reply #15 on: September 12, 2011, 08:10:04 pm »
Unless you have a badly marred crescent wrench, then i see no reason why two perfectly flat surfaces should have issue together?
Reply #16September 12, 2011, 08:17:56 pm
nathan_b
  • 361
« Reply #16 on: September 12, 2011, 08:17:56 pm »
Although that may be true, I am saying that it is an avoidable, unnecessary risk.
Reply #17September 13, 2011, 03:04:56 am
Mark(The Miser)UK
  • 1557
« Reply #17 on: September 13, 2011, 03:04:56 am »
Well either way this is a perfect example to you in the future of why to not use the cam lock when your tightening or loosening the cam sprocket bolt. Instead use a large adjustable wrench on one of the cam lobes.
I would also shine a light or poke a wire down the drains of the motor to see if there isn't any chunks stuck up in there.
Definitely pull the pan for sure.
I think it would be better to use vice grips on the raw casting of the cam instead of on the lobes.
You dont use a vice on crank journals to remove the timing gear do you?
(extreme example, but you get my point, hardened metals should not fight)
Absolutely.
 With my engine; I undo with a wrench on the bolt, and then a sharp tap with a 2lb hammer always works.Tightening with same procedure.
Mind you though I never overgraunch this bolt in the first place, because I always clean to a 'matt finish' both sides of  the taper.
When the fitting is good even finger tight has some grip.
'CAD'-man's tap on the bolt head before final tightening is a good policy too.
Mark-The-Miser-UK
Reply #18September 13, 2011, 05:04:02 am
92EcoDiesel Jetta
« Reply #18 on: September 13, 2011, 05:04:02 am »
Vice grip on the cam casting to tighten the cam sprocket nut? I'be be worried of it slipping and gouging the head. Make or buy a sprocket lock tool. Long piece of angle iron and 2 big bolts. The scissor type is the best design since it self adjusts to the holes in the sprocket.
Reply #19September 13, 2011, 08:11:22 am
nathan_b
  • 361
« Reply #19 on: September 13, 2011, 08:11:22 am »
Not to tighten/loosen the nut, just for fine movement of the cam. Always use a pulley counterhold. Gripping the cam risks snapping it.
Reply #20September 13, 2011, 11:38:09 am
silentdub
  • 135
« Reply #20 on: September 13, 2011, 11:38:09 am »
Wouldn't that throw off the balance of the shaft and cause vibration and premature wear/failure?
Reply #21September 13, 2011, 11:05:48 pm
nathan_b
  • 361
« Reply #21 on: September 13, 2011, 11:05:48 pm »
if bending pulleys were an issue, they wouldnt have you knock it loose with a drift.
Also, They seem to be cast? (maybe wrong) but they seem like they would fracture long before they would bend.
plus they are just tough and over engineered.
Reply #22September 14, 2011, 03:47:56 am
rs899
  • 647
« Reply #22 on: September 14, 2011, 03:47:56 am »
Someone gave me a complete (hydro) engine and the cam looks like this one.  I was afraid to use it ( hydro cams are in short supply south of the border), but looks like it's a pretty even split of opinions.
