Author Topic: 6 1/2" speakers.. can it be done!?  (Read 7120 times)
September 01, 2011, 07:18:14 am
« on: September 01, 2011, 07:18:14 am »
In the front doors!? Got a line on some decent 6.5" components.. Can i make it work??
Reply #1September 01, 2011, 07:36:11 am
Re: 6 1/2" speakers.. can it be done!?
« Reply #1 on: September 01, 2011, 07:36:11 am »
Reply #2September 01, 2011, 09:26:12 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #2 on: September 01, 2011, 09:26:12 am »
It can but you may not consider it pretty.   I didn't do it, but my '86 came with them installed.   The way they were installed would rule out many speakers as you need a very shallow surface mount and grille cover.   I'll get pics when I get home from work.
Calvin
91 VW Golf 1.6NA 5spd
Reply #3September 02, 2011, 08:22:58 am
« Reply #3 on: September 02, 2011, 08:22:58 am »
you can put 6x9s in your doors if you got wing windows, and the speakers are shallow enough..
now you gotta have something to power (amp) those speakers with.. bigger speakers distort alot faster than small ones..
Reply #4September 02, 2011, 05:43:28 pm
« Reply #4 on: September 02, 2011, 05:43:28 pm »
I would probably rather the JVC Arsenals I posted in the second post.
5 1/4" and a pretty shallow magnet. And 1" tweets instead of 3/4".
Get these and some 6.5" rounds for the back deck, amp all four. And then a folded horn subwoofer for the trunk.. Which can produce 108db on as little as 120 wattd rms.. A smooth 88db on just 20w. All with just an 8" woofer too. Frequencies between 20-250hz. All above 90db at 120w.
Money. :)
Reply #5September 03, 2011, 08:46:44 am
« Reply #5 on: September 03, 2011, 08:46:44 am »
LMFAO...
just checked the efficiency of the sub in my trunk..
86.3 dB/spl
if it were in a folded horn, it would make your ears bleed..
anyway, back to your car..
i wasnt suggesting that you install 6x9 speakers in your front doors, just stating that it CAN be done..
and honestly, idk that i would waste my time on a 5.25" speaker, because they are not much better than what the cars came with factory.. the 6.5" speakers would do better.
i would do 6.5" speakers all the way around, with a nice amp to push them..
then again, its all up to you..
Reply #6September 03, 2011, 02:08:41 pm
« Reply #6 on: September 03, 2011, 02:08:41 pm »
http://billfitzmaurice.net/autotuba.html
8" $40 woofer, with 20w rms could out do your 86db. And thats the point. small wattage, no draw on the electrical, cost effective.
Reply #7September 05, 2011, 04:19:53 pm
« Reply #7 on: September 05, 2011, 04:19:53 pm »
sure, the $40 sub will do good, but its not going to make the same sound pressure levels as my $1200 sub with 1600 RMS
(no, i did not pay retail price for the sub, im not that rich)
yes, the amps do take a toll on my charging system, i really need to figure out a new way to drive the alternator. im thinking about a serpentine system, because i have everything besides the water pump pulley..
Reply #8September 05, 2011, 04:29:43 pm
« Reply #8 on: September 05, 2011, 04:29:43 pm »
It'll actually be pretty damn close ;) :P
On average 10-12db hotter than most commercial 12" subwoofers with a fraction of the power.. seems a no brainer to me.. lol
Reply #9September 05, 2011, 05:02:59 pm
« Reply #9 on: September 05, 2011, 05:02:59 pm »
dude, no.. i cant see it happening.. your $40/20w rms sub will NOT shake your brain and eyeballs like my sub does.. it cant make the same pressure. there is not enough energy going into the sub to have that much energy coming out of it..
im not trying to get into one of those "my stereo is better" arguements, but i just dont see a $40/20w rms sub getting anywhere near as loud as the inefficient sub in the back of my car.. my sub prolly puts out about 130-135 dB.. but it damn near knocks the wind out of you also..
Reply #10September 05, 2011, 05:15:33 pm
« Reply #10 on: September 05, 2011, 05:15:33 pm »
I said 20w will keep up with most 86-89db.. The 120w rms that the speaker can handle will produce these numbers;
What kinda of sub is this exactly? Which frequencies is it going to produce? above 100db from 40-200hz? I also don't wish to start an argument, but mostly anything over 105db is pretty much useless to listen to. And using 1600w rms for it? jesus christ.
Reply #11September 05, 2011, 05:27:59 pm
« Reply #11 on: September 05, 2011, 05:27:59 pm »
this is the link to it.. its a JL Audio W7..
http://mobile.jlaudio.com/products_subs.php?series_id=40
its a high end/competition sub..
the highest frequencies that big boy sees is 80hz
yes, 1600w RMS..
Reply #12September 05, 2011, 05:35:52 pm
« Reply #12 on: September 05, 2011, 05:35:52 pm »
13.5" 50lbs and 1600w rms sweet baby jesus.
Jus sayin, for $200 total i have a sub that sounds just as good ;)
Reply #13September 05, 2011, 10:18:41 pm
ToddA1
  • 434
« Reply #13 on: September 05, 2011, 10:18:41 pm »
I had 6.5s in my doors before.  I mounted the speakers to the doors, not the panels. I also needed to trim the grill edges so they'd sit lower and the window cranks would clear them.
Cutting the holes was tedious, so it'd look clean, but it worked out.  I used door edge trim to cover the cut edge, and it looked decent.  I should have pulled the vinyl around, but it was an afterthought.
-Todd
Reply #14September 05, 2011, 10:49:27 pm
« Reply #14 on: September 05, 2011, 10:49:27 pm »
for a mere $40 more than you spent, i have a big (13.5" 50lbs and 1600w rms sweet baby jesus) subwoofer, along with a box that i built myself that cost nothing..
i did pay ~$300 for the amp tho..
