Author Topic: Pistons  (Read 3187 times)
August 31, 2011, 06:52:27 am
jbm2k6
Pistons
« on: August 31, 2011, 06:52:27 am »
I'm looking for first oversize pistons and rings for a 1.6 NA. Does anyone recommend a particular vendor for these? I haven't had much luck searching on my own. AutohausAZ only sells them individually.
Thanks!
Reply #1August 31, 2011, 07:10:54 am
dankcorey22
  • 379
    Cummins!
    • Anything that runs
Re: Pistons
« Reply #1 on: August 31, 2011, 07:10:54 am »
How much over? .020 (.5MM) or .040 (1.0MM)? Prothe has got some pistons they are pretty good quality... BUT REPLACE THE RINGS WITH SOME TOTAL SEAL RINGS! The rings that are on it SUCKS!
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #2August 31, 2011, 07:13:44 am
mmitocky
  • 23
Re: Pistons
« Reply #2 on: August 31, 2011, 07:13:44 am »
I needed to buy pistons for my Audi 5-cyl diesel, and wanted the Kolbenschmidt pistons from Autohaus, but they only sold them in sets of 4.  After asking if they could sell me 5, someone there said they would check with their supplier -- they did, and they suddenly allowed you to buy them individually.  You say "you can only buy them individually", but I am pretty sure the price per piston is just one-fourth of what the 4 piston set was....so the total price isn't really affected.  FWIW, the Kolbenschmidt pistons are EXCELLENT quality; the price is indicative of that...
Reply #3August 31, 2011, 08:18:30 am
jbm2k6
Re: Pistons
« Reply #3 on: August 31, 2011, 08:18:30 am »
Decided to combine this into one post, instead of having two.
I need .20 over. I had read that a few folks had relatively good luck with prothe's pistons, but I just wasn't sure about taking a chance on something like that, myself. When I got the car, I got a box of new parts from him with it, and I wasn't too impressed with the quality.
This raises the question, at least to me, should I consider total seal rings if I do go forward with, say, Kolbenschmidt pistons?
I didn't think about it that way. I know that particular brand is known for quality, too. Thanks for putting it into perspective. :-)
« Last Edit: August 31, 2011, 08:25:03 am by jbm2k6 »
Reply #4August 31, 2011, 01:04:57 pm
monomer
  • 414
Re: Pistons
« Reply #4 on: August 31, 2011, 01:04:57 pm »
Thats where I got my TD (cut skirt) pistons, same brand. Great quality, and the price reflects that.
www.michiganvw.org
Reply #5August 31, 2011, 01:07:41 pm
Re: Pistons
« Reply #5 on: August 31, 2011, 01:07:41 pm »
there around $100 a piston arent they?
Reply #6August 31, 2011, 04:06:29 pm
camboscams
  • 324
Re: Pistons
« Reply #6 on: August 31, 2011, 04:06:29 pm »
I've got King brand from partsplace and they're still running strong i've had it to 1400 degrees a few times too and have the piston oiler notch already cut out. about 100$ a piston too. FWIW
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #7September 01, 2011, 06:43:42 am
jbm2k6
Re: Pistons
« Reply #7 on: September 01, 2011, 06:43:42 am »
It makes me feel a bit better spending the money on that knowing I'll get the good stuff.  I've ordered a few parts which said "German" in the description, but arrived to say "engineered in Germany, made in China". I'm just hesitant to put out a lot of money for something that may not have the level of quality control or attention to detail that I'm looking for, as I'm on a strict budget and really can't afford to replace a motor due to poor quality parts falling to pieces on me. Maybe I'm being a little over the top, though?
Reply #8September 01, 2011, 07:51:11 am
BigVWman
  • 332
Re: Pistons
« Reply #8 on: September 01, 2011, 07:51:11 am »
If i had the money to shell out i would go german! There is a definite quality difference, whether you'll ever see any benefit from that difference is a question but the piece of mind is worth it if you can afford it. The only genuine german parts i have had prematurely fail is one batch of meistersatz cv boots about 18 yrs ago!
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #9September 01, 2011, 02:06:35 pm
monomer
  • 414
Re: Pistons
« Reply #9 on: September 01, 2011, 02:06:35 pm »
can't find the invoice, I think it was around $430 on that order, I may have ordered some other goodies also.
Figure, if you build it: why not spend the extra $$ to do it proper. Next parts (besides a TD pump) on the list is the new con rods that are out now. The parts for this build have taken three years to acquire.; Take your time & do it right! You can never go wrong with german parts. Nicest OE piston's I've ever seen! Skirts are coated from factory!
www.michiganvw.org
