Author Topic: Getting ready to install new injector nozzles in my 1V Ecodoiesel  (Read 4237 times)
August 23, 2011, 02:48:07 pm
92EcoDiesel Jetta
Now that the head gasket job is done and my injection pump reseal has stopped all leaks, it is time to install, adjust and pop test the Monark DNO SD 297 nozzles. The set of injectors in the car pop tested within specs and very closely matched with good patterns, but they probably have 180K miles on them. I was thinking of keeping them as a spare working set and rebuild a set of 155 bar and 135 bar injectors that were given to me. They were pretty cruddy looking on the outside and were all streamers and did not spray well. Upon disassembly, they had siezed needles in the nozzle and some had  rust inside the bodies so I will not be using those.
Are the 130 bar and 155 bar injector bodies physically the same other than the markings stamped into the bodies?
« Last Edit: August 23, 2011, 03:13:55 pm by 92EcoDiesel Jetta »
Reply #1August 23, 2011, 03:58:57 pm
Luckypabst
  • 502
Re: Getting ready to install new injector nozzles in my 1V Ecodoiesel
« Reply #1 on: August 23, 2011, 03:58:57 pm »
Yes.
'82 TD Westy
'81 NA Caddy
Reply #2August 25, 2011, 06:25:53 am
Mark(The Miser)UK
  • 1557
« Reply #2 on: August 25, 2011, 06:25:53 am »
The difference between injectors is the shim, possibly variation in the spring, [but 130 to 155 bar attainable from either springs], and the nozzle SD code, but all nozzles for the 1.5 to 1.6 entirely interchangeable.
Back to your torquing proceedure for the 1V.
Same bolts, same gaskets and  the exact same part no for 1V as the MF [1.6TD] head, so torquing procedure the same even if omitted by the wonderous Bentley rag mag
« Last Edit: August 25, 2011, 11:50:39 am by Mark(The Miser)UK »
Mark-The-Miser-UK
Reply #3August 25, 2011, 11:08:38 am
92EcoDiesel Jetta
« Reply #3 on: August 25, 2011, 11:08:38 am »
This is the Bentley I have
http://www.bentleypublishers.com/findMyCar.do?action=getresults&forward=index&make=Volkswagen&model=jetta&year=1992
Getting back to the injectors, have you swapped springs between injectors to fine tune the pop pressures? I measured all the springs taken from the injectors and they are not all the same length so I was thinking of swapping them around after doing a pop measurement. For the shims, 0.05 mm difference equates to approx 5 bars. Is there a rule of thumbs for spring length?
« Last Edit: August 25, 2011, 11:48:37 am by 92EcoDiesel Jetta »
Reply #4August 25, 2011, 12:11:50 pm
Mark(The Miser)UK
  • 1557
« Reply #4 on: August 25, 2011, 12:11:50 pm »
Spring lengths do vary, but so do their strength, so swapping stuff around takes a little more skill than immediately apparent. Bits of razorblade and tape measure spring help get the match closer in my experience
« Last Edit: August 25, 2011, 02:12:16 pm by Mark(The Miser)UK »
Mark-The-Miser-UK
Reply #5August 25, 2011, 01:28:06 pm
Luckypabst
  • 502
« Reply #5 on: August 25, 2011, 01:28:06 pm »
Why is this spiraling into another torque discussion?
'82 TD Westy
'81 NA Caddy
Reply #6August 25, 2011, 01:48:10 pm
92EcoDiesel Jetta
« Reply #6 on: August 25, 2011, 01:48:10 pm »
.....Spring lengths do vary, but so do their strength, so swapping stuff around takes a little more skill than immediately apparent. Bits of razorblade and tape measure spring help get the match closer in my experience[/color]
Have you disassmebled injectors after extended use and inspect the bits of razor blade and tape measure spring shims? How did they hold up? The worry is their hardness (or lack of or the wrong temper) and getting beat to a pulp. If true, the pulp bits can clog the nozzle passages.
Reply #7August 25, 2011, 01:58:52 pm
Mark(The Miser)UK
  • 1557
« Reply #7 on: August 25, 2011, 01:58:52 pm »
Hopefully the info I've just given provides sufficent knowledge to close the other thread, and provide useful information for this thread, and I couldn't be bothered to change threads, but perhaps I might transfer the data.
Spiralling? As if...  :'(
Mark-The-Miser-UK
Reply #8August 25, 2011, 02:10:29 pm
Luckypabst
  • 502
« Reply #8 on: August 25, 2011, 02:10:29 pm »
Proper shims are available at a nice price. I forget the guys contact info but you can find it easily enough via searching the site. I purchased 4 of every size and I believe it came in somewhere around $100.
Chris
'82 TD Westy
'81 NA Caddy
Reply #9August 25, 2011, 02:20:38 pm
92EcoDiesel Jetta
« Reply #9 on: August 25, 2011, 02:20:38 pm »
Yes I know you can buy them. Not that I'm about to make my own shims. It's just that I am interested in Mark making his own and his outcome.
Chris
Reply #10August 25, 2011, 02:26:27 pm
Mark(The Miser)UK
  • 1557
« Reply #10 on: August 25, 2011, 02:26:27 pm »
Chris
A good price, I suppose, but they often don't get a good enough match, and soon you run out of the closest ones and then are 8 bar out unless you only have one  or two injector sets
Mark-The-Miser-UK
Reply #11August 26, 2011, 06:19:11 pm
92EcoDiesel Jetta
« Reply #11 on: August 26, 2011, 06:19:11 pm »
The new nozzles are in. I ended up rebuilding the set of injectors that were in the car since they have not sat around like the ones given to me. I used the same shims and all 4 injectors popped at 2300 psi without any adjustment! This is testament to the quality of the Monark nozzles.
Did you know the springs and thrust pins from a 135 bar injector are not interchangeable with 155 bar injectors? The thrust pin diameter (the part that fits in the spring) is bigger on the 155 bar injectors.
Reply #12August 27, 2011, 02:43:11 am
Mark(The Miser)UK
  • 1557
« Reply #12 on: August 27, 2011, 02:43:11 am »
Yep I found that out, with one injector I was rebuilding. That may have been how I broke one onf my new old stock French 293's. One of the 3 remaining had a poor fit needle to nozzle as well, so my first attempt to have new nozzles failed, and I went back to  salvaged ones  for a few $ each, matched and pop tested by me.
 You can of course go the other way, or keep the spring...
EDIT What break pressure are you running for your 297's Ah I see 158bar. Interestingly one of the lists that I have mention the 297's as used in the ECO, they were set to 130 bar.
The only real concern is your timing may well be out, but if you're happy to 'Hagar' it then you'll be fine ;D
« Last Edit: August 27, 2011, 03:55:46 am by Mark(The Miser)UK »
Mark-The-Miser-UK
Reply #13August 27, 2011, 11:40:07 am
92EcoDiesel Jetta
« Reply #13 on: August 27, 2011, 11:40:07 am »
The injector bodies from my car are marked 155 bars. When disassembled, I found 297 French nozzles in there. I have no idea if these are originals or if they have been replaced at some point by the PO. Do you know what nozzles and pop pressure the Ecodiesel's should have? I'd like to build another set of injectors set to 130 bars and experiment with getting higher fuel economy. The new Monark 297 nozzles are running really well, same power as the old French 297's. The difference I am noticing is the power is smoother and there is less smoke both at idle and full throttle. With the old nozzles, if I put the pedal to the metal I'd get a cloud of smoke. With the Monarks, no more cloud. I assume the old nozzles are worn with bigger orifices and letting more fuel through? Do you know the relationship between the amount of erosion on the nozzle face vs mileage on the injectors?
With regards to the different thrust pins and springs, from what I can tell, you can interchange them as a set but not mix them. e.g. if you take a thrust pin from a 155 bar nozzle and put it in a 130 bar spring, the thrust pin will fit into the hole in the spring due to interference. If you take a thrust pin from a 130 bar injector and put it in a 155 bar spring, it will fit but it will be very loose. I do not know if the 155 bar springs are stronger than the 130 bar springs. The shims taken out of the 130 bar injectors are thinner than shims taken from the 155 bar injectors.
