Author Topic: Cleaning oil out of cooling system 1.6 Rabit PU  (Read 4172 times)
August 23, 2011, 10:44:32 am
85Jettaturbo
« on: August 23, 2011, 10:44:32 am »
Sorry if this has been covered before but the search feature was not cooperating with me.  The head gasket was leaking oil into the cooling system and after I replace head gasket I need to clean the cooling system of oil.  What's the best way or product to buy to do this?  Thanks for all replies.
Brent
Reply #1August 23, 2011, 11:02:23 am
Re: Cleaning oil out of cooling system 1.6 Rabit PU
« Reply #1 on: August 23, 2011, 11:02:23 am »
coolant flush..
its basically a soap/detergent safe for the cooling system..
or dawn dish soap works too. then flush with water till clean..
*fill system with WATER. add some dish soap/coolant flush. run it for a day or so, drain, repeat if necessary. then flush it out real good and re-fill with coolant*
and by flushing, i mean take the thermostat out, and take the top rad hose off, and back flush with a garden hose thru the top water neck.
re-fill
good to go.
Reply #2August 23, 2011, 12:56:46 pm
guy plain
  • 121
« Reply #2 on: August 23, 2011, 12:56:46 pm »
and pickeling vinager will help remove any scale or rust in the cooling system as well.....cheap and enviromentely safe to...
Reply #3August 23, 2011, 03:45:49 pm
81 vw pu
« Reply #3 on: August 23, 2011, 03:45:49 pm »
First drain the coolant/oil mixture then fill with water. Then run the engine with a garden hose trickling into the reservoir and float the oil to the top of the tank and let it spill over.
After removing as much oil as you can then do several flushes with cascade dishwasher detergent. Repeat the garden hose in reservoir before dumping each flush as any oil will float to the top.
Its messy as hell but it works.
Reply #4August 24, 2011, 09:08:33 am
« Reply #4 on: August 24, 2011, 09:08:33 am »
i was gonna say something like that, but i hate messes that big..
Reply #5August 24, 2011, 11:39:02 am
guy plain
  • 121
« Reply #5 on: August 24, 2011, 11:39:02 am »
i like that kind of mess here....keeps the dust down... lol
Reply #6August 25, 2011, 11:45:44 am
« Reply #6 on: August 25, 2011, 11:45:44 am »
all that oil under the hood should keep the dust away from your air cleaner atleast..  hahaha
Reply #7August 25, 2011, 02:53:11 pm
guy plain
  • 121
« Reply #7 on: August 25, 2011, 02:53:11 pm »
 well i live in a hot dusty town....and do alot of my wrenching in the unpaved driveway.....bit of oil in hot water really dose help...lol
Reply #8August 30, 2011, 09:25:39 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #8 on: August 30, 2011, 09:25:39 am »
Washing soda will do the trick.  It's what Cummins has recommended to us.    Mix with fresh water and heat cycle the engine, drain, repeat until no evidence of oil in the water.
Calvin
91 VW Golf 1.6NA 5spd
