Author Topic: Malone's MK3 TDI  (Read 49522 times)
August 16, 2011, 11:29:30 pm
  • 1156
    • Malone Tuning Ltd.
Malone's MK3 TDI
« on: August 16, 2011, 11:29:30 pm »
You probably remember my '97 Golf CL with the early 1.6/1.9TD Frankenmotor: Part 1 and Part 2. The engine died due to v-belt slippage on the water pump. The engine was eventually sold to Dave aka 935racer aka Passenger Performance, who dynoed 192whp with a bigger turbo. I bought a 2006 Jetta TDI DSG and it bores the heck out of me (my wife also took possession of it).
I still think of picking up another IDI, but I'm an ECU tuner, TDI donors are becoming cheaper, TDIs tend to get better fuel economy, and they support more low-RPM torque out of the box, so I decided to go that route for my new daily driver.
I picked up a '96 Golf CL and a '98 Jetta TDI donor car.
Progress:
  • Perform intake cleaning
  • Perform TDI timing belt job
  • Install performance camshaft
  • Install 400ft-lb torque clutch
  • Install TDI engine + transmission in Golf
  • Install 5 lug 11.3" VR6 brake parts with all new suspension bearings
  • Install TDI pedal cluster in Golf
  • Install telescoping steering column in Golf
  • Install TDI wiring harness in Golf - almost complete. JS Performance takeover at this point
  • Hook up coolant system and V belts
  • Install cruise control in Golf
  • Install heated seats in Golf
  • Install coilovers
  • Make a high MPG / performance switchable-on-the-fly tune.
  • Completely re-do interior
  • Full body work + repaint
Pulling the 1.8L 8v 90HP gas motor from the Golf:
Pulling the 1.9L 8v 90HP AHU TDI from the Jetta:
Cleaned out this intake gunk:
My friend helping pull the dashboard. We removed the dash+rebar from both vehicles. The Golf's rebar was literally dripping with rust while the Jetta's was rust-free (factory painted).
The joy of wiring (as I progressed into it I learned that it's not really difficult, just time-consuming):
Due to my upcoming 2 weeks absence, I'm leaving the rest of the conversion to JS Performance:
« Last Edit: November 25, 2011, 07:46:30 pm by malone »
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #1August 17, 2011, 04:52:30 am
Re: Malone's MK3 TDI
« Reply #1 on: August 17, 2011, 04:52:30 am »
Good work. Can't wait to see what you do with the tune.
Reply #2August 17, 2011, 06:08:58 pm
catlin_cava
  • 1954
« Reply #2 on: August 17, 2011, 06:08:58 pm »
Your my Hero! Ive always wanted to do a AHU into a MK3 2 door. Cant wait to see it done!
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #3August 17, 2011, 08:15:08 pm
  • 1156
« Reply #3 on: August 17, 2011, 08:15:08 pm »
Thanks guys. I'm thinking of trying a supercharger, but that's for way later (possibly at least a year).
Pros:
  • Easy to install (replaces the A/C compressor) with short IC plumbing. A "250HP" supercharger that I have in mind is more compact than the A/C compressor
  • Instant throttle response with virtually no boost lag
  • Apparently no other TDI owner has tried supercharging yet
Cons:
  • Less efficient than a turbo
  • Fuel economy may be in a world of hurt
A clutched supercharger will reduce the MPG hit, however, and I won't mind daily driving NA if I want to conserve fuel. Twin-charging using stock turbo + big supercharger is another possibility and still easy to setup.
Anyway I'll post updated pictures in a couple weeks or so.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #4August 17, 2011, 10:25:12 pm
RadoTD
  • 513
    Stage WTF
« Reply #4 on: August 17, 2011, 10:25:12 pm »
Hmmm... what supercharger would that be? Lysholm possibly? I've always liked the idea of adding a supercharger in my engine bay somewhere  :P
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #5August 17, 2011, 10:55:10 pm
nathan_b
  • 361
« Reply #5 on: August 17, 2011, 10:55:10 pm »
I bet a k03 would just spin off somewhere and take off into space if you double-charged it lol.
1-Here is the end all ahu setup,
2-having your ecu modded to control vnt
3-install vnt
4-be a boss
5-???
6-profit?
 ;D :P
sorry too much time on vortex.
I would try a supercharger, here is a trick, if you block the vac line to the map sensor, you can do a looot of stuff without going into limp mode.. not sure how you would control fueling based on boost, but it would sound SICCKK, and you could put a cool exhaust on it instead of the played straightpipe.
Just food for thought.
Reply #6August 18, 2011, 07:39:07 am
  • 1156
« Reply #6 on: August 18, 2011, 07:39:07 am »
I can't disclose the supercharger yet. It's an agreement that I have with a shop who's helping with the project. I hate withholding information, but it will be revealed if it's installed in my car. I can however tell you that it's not a Lysholm, which is a bit too large physically and too noisy.
I might tune a 2001 MK4 Golf TDI with an Eaton supercharger. Here's a picture of his exhaust that's already installed:
He definitely needed the muffler as his car is way too loud without it.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #7August 18, 2011, 07:56:42 am
  • 1156
« Reply #7 on: August 18, 2011, 07:56:42 am »
install vnt
I already have a custom rear engine mount that will allow room for a standard VNT layout, just in case I go that route. VNT is good, but everyone including their mother and their dog have already done a VNT conversion. I tuned one TDI with THREE VNT turbos.
I will eventually decide between a GTB1749VB (cheap, simple to install, and still strong - highly recommended for a budget daily driver), a GTB1756VK (faster spool, more power overall, but it's either much more expensive or time-consuming to setup), or supercharger (unique, potentially instant throttle response, cool noise, but the charger that I'm considering is very expensive).
I don't want to push more than 24 PSI boost with the stock 300,000 km AHU engine, so whatever I do, I'm going to take it easy until I'm ready to drop in a fresh ALH TDI engine that can handle more boost and more torque.
I will keep the MAP sensor and I will experiment with MAF delete. Either the MAP or MAF values will determine how much fuel to inject, pretty simple. I will also either modify my boost control map to reflect the supercharger's boost ouput based on RPM (that's one way to keep the ECU happy), or disable the 'negative boost deviation' code/limp and simply set the boost control map to whatever max. boost I'll allow. Easy workaround. Another way is to spend time completely re-writing the ECU and remove all N75 control (it's pretty well entrenched in the stock software), but that won't make a better running engine.
« Last Edit: August 18, 2011, 07:58:51 am by malone »
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #8August 18, 2011, 10:50:29 am
nathan_b
  • 361
« Reply #8 on: August 18, 2011, 10:50:29 am »
Malone,
I'd pay $500 for a seminar where you thoroughly explained how to modify ecu's in the manner. (know how to immo delete?? lol)
You are beyond me for now.
Reply #9August 19, 2011, 12:49:16 pm
  • 1156
« Reply #9 on: August 19, 2011, 12:49:16 pm »
Last night someone smashed the Golf's driver side window and stole the turbo & downpipe. First time I've experienced a break-in. I posted this project in a local VW forum 2 days ago and I wonder if someone there decided that he needed my parts.
The turbo and downpipe had 300,000km on them so I'm not too bothered. It gives me an excuse to get newer ones. I also bought an identical MK3 Golf parts car for $250 (with Hella MK4-look headlights!) so I can replace the glass or door with minor inconvenience.
My Golf was parked outside and it's my fault for not properly securing all the parts. JSP was kind enough to offer a replacement turbo. I'm exploring various boost options right now.
« Last Edit: August 19, 2011, 12:51:56 pm by malone »
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #10August 19, 2011, 01:40:38 pm
BigVWman
  • 332
« Reply #10 on: August 19, 2011, 01:40:38 pm »
That is pretty crappy 300k or not, i have to say if you ever catch them i hope you extract some justice! keep eye on local cl and ebay!
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #11August 19, 2011, 01:51:12 pm
rallydiesel
  • 1880
« Reply #11 on: August 19, 2011, 01:51:12 pm »
People who steal stuff need to have their hands cut off.
Anywho, nice build except for the mk3 part.  ;D
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #12August 19, 2011, 05:07:25 pm
RadoTD
  • 513
    Stage WTF
« Reply #12 on: August 19, 2011, 05:07:25 pm »
Maybe I should post a wanted ad on Dubberz and see if anyone in the abbotsford area has a turbo and downpipe to sell ;)
Reply #13August 19, 2011, 07:18:46 pm
catlin_cava
  • 1954
« Reply #13 on: August 19, 2011, 07:18:46 pm »
Do It!!!! Then have some VWDiesel Justice :P
and That really sucks about the break in, I had my TDI broken into last week, they didn';t have time to take anything before I came flying out of the house
Catlin
Reply #14August 19, 2011, 09:31:38 pm
keaton
  • 90
« Reply #14 on: August 19, 2011, 09:31:38 pm »
cool, so how much are you selling for?  ;D
2006 1.9L BRM 5-speed Manual... 100% Stock :(
Standalone VGT/VNT controller: http://dmn.kuulalaakeri.org/vnt-lda/
My CAN Bus video recorder: http://www.youtube.com/watch?v=2QuRBQzGs-c
