TDI Engine -General Info
2000 ALH anti-shutter valve open "all" the time
Topic: 2000 ALH anti-shutter valve open "all" the time (Read 9271 times)
August 16, 2011, 05:59:18 am
dieselherb1
August 16, 2011, 05:59:18 am »
I have 2000 Jetta, the anti-shutter valve is activated all the time. Tried 3 different valves same thing. Any ideas?
August 16, 2011, 08:34:17 pm
vanagonturbo
Re: 2000 ALH anti-shutter valve open "all" the time
August 16, 2011, 08:34:17 pm »
The anti shudder valve is only closed for a temporary time during engine shut off. After it closes, it opens back up so you can start the engine. Maybe have a buddy help you and watch it during engine shut off and see if it closes and then opens back up.
August 17, 2011, 07:55:54 pm
dieselherb1
August 17, 2011, 07:55:54 pm »
It closes and stays close as long as there is vacuum. When engine is running if I reconnect the valve it will shut down the engine with the key still on
August 17, 2011, 07:59:35 pm
vanagonturbo
August 17, 2011, 07:59:35 pm »
It is very likely that you have a faulty vacuum solenoid. IIRC it is the one in the little cavity in the middle of the intake manifold. If you have Vagcom, you can run an output test which will turn the valve on and off every second. You can check for voltage at the plug to the solenoid. If the voltage is fluctuating but when the solenoid is connected its not clicking, then you need a solenoid. I bet 200 internets this is your problem
August 19, 2011, 01:24:37 pm
BigVWman
August 19, 2011, 01:24:37 pm »
Is it possible the vacuum lines on solenoid are reversed?
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby, 87 gti, 01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
August 19, 2011, 01:28:02 pm
August 19, 2011, 01:28:02 pm »
More often, I find they've fallen or been knocked off.
August 22, 2011, 10:56:16 am
vanagonturbo
August 22, 2011, 10:56:16 am »
Quote from: BigVWman on August 19, 2011, 01:24:37 pm
It doesnt really matter one way or the other since the solenoid is like a gate. Its either open or closed.
August 22, 2011, 02:31:31 pm
BigVWman
August 22, 2011, 02:31:31 pm »
isn't there three lines( vac in, output and vent) and if vacuum was applied to the vent line instead of where it should be wouldn't that allow the anti shudder to be open all the time and close only momentarily when you shut the car off?
Tim
August 22, 2011, 03:49:09 pm
vanagonturbo
August 22, 2011, 03:49:09 pm »
There are only two vacuum connections on the valve for the anti shutter flap. I think you are thinking of the EGR or charge pressure control solenoids. Those CAN be connected incorrectly and cause wierd stuff, but the anti shutter valve only has two connections.
August 22, 2011, 04:53:36 pm
BigVWman
August 22, 2011, 04:53:36 pm »
Yep your right I was thinking n75 n18 type stuff! Sorry for the confusion!
Tim
