are you really that lazy?
Quote from: R.O.R-2.0 on July 26, 2011, 01:07:01 amare you really that lazy?Yup, i don't have the tool to get the plugs out.. and I'm not confident on my own filling procedure TBH. I know we've gone over this Kev, and where the fluid should sit on the speedo gear.. but i just dunno.. There is a really good trans place in town, and he even knew the tranny code of my gf's auto 3pd off the top of his head.. Me thinks he knows vw trannies.
not a chance
Quote from: R.O.R-2.0 on July 26, 2011, 01:07:01 amnot a chance x2 I just did mine, was not a problem. the two plugs are I think 17 mm same size as the wheel bolts anyway. you will need to take the drivers side tire off. you don't even need to make a tool, a wheel bolt and wrench will work.
Quote from: Grey_Smoke on July 26, 2011, 01:40:41 amQuote from: R.O.R-2.0 on July 26, 2011, 01:07:01 amnot a chance x2 I just did mine, was not a problem. the two plugs are I think 17 mm same size as the wheel bolts anyway. you will need to take the drivers side tire off. you don't even need to make a tool, a wheel bolt and wrench will work.not necessary, just turn it hard to the left. it creates more than enough room to access all the plugs. atleast on all my cars.i took a bolt with a 17mm head, and welded a GM lug nut to the end of the threads. instant drain plug tool..
You turned it out with just a wrench? Lol, I ended up draining mine out the end of the 5th lol
