Author Topic: Having a shop change my trans fluid?  (Read 7492 times)
July 25, 2011, 10:00:02 pm
« on: July 25, 2011, 10:00:02 pm »
Do you think its worth that couple bucks if this is the one job you pay someone else to do? :P
Reply #1July 25, 2011, 10:07:01 pm
Re: Having a shop change my trans fluid?
« Reply #1 on: July 25, 2011, 10:07:01 pm »
not a chance i would pay someone to do it.. being that it has an abnormal fill procedure..
fill till it comes out the fill hole, then add .5L more thru the speedo hole..
are you really that lazy?
Reply #2July 25, 2011, 10:11:20 pm
« Reply #2 on: July 25, 2011, 10:11:20 pm »
Yup, i don't have the tool to get the plugs out.. and I'm not confident on my own filling procedure TBH. I know we've gone over this Kev, and where the fluid should sit on the speedo gear.. but i just dunno.. There is a really good trans place in town, and he even knew the tranny code of my gf's auto 3pd off the top of his head.. Me thinks he knows vw trannies.
Reply #3July 25, 2011, 10:19:48 pm
« Reply #3 on: July 25, 2011, 10:19:48 pm »
took me 5 minutes to make a tool for the drain/fill plugs.
3 spd autos are easy.. gas came with one code, and the diesel came with the other code.. and those were the only ones offered. (late mk2 atleast)
if i can successfully change my trans fluid after 12 beers, and a pint of Jager, then i think you should be more than able to.. its really not rocket science, and only takes 10 bucks of oil.
Reply #4July 25, 2011, 10:40:41 pm
Grey_Smoke
  • 83
    fling wing for the win.
« Reply #4 on: July 25, 2011, 10:40:41 pm »
not a chance
x2 I just did mine, was not a problem.  the two plugs are I think 17 mm same size as the wheel bolts anyway.  You don't even need to make a tool, a wheel bolt and wrench will work.
« Last Edit: July 25, 2011, 10:45:00 pm by Grey_Smoke »
2001 TDI
86 Jetta Coupe TD - Still going together
sold - the Gutless wonder - 97 AAZ
An Oldvolks Home
Reply #5July 25, 2011, 10:44:58 pm
« Reply #5 on: July 25, 2011, 10:44:58 pm »
not a chance
x2 I just did mine, was not a problem.  the two plugs are I think 17 mm same size as the wheel bolts anyway.  you will need to take the drivers side tire off.  you don't even need to make a tool, a wheel bolt and wrench will work.
not necessary, just turn it hard to the left. it creates more than enough room to access all the plugs. atleast on all my cars.
i took a bolt with a 17mm head, and welded a GM lug nut to the end of the threads. instant drain plug tool..
Reply #6July 25, 2011, 10:46:26 pm
Grey_Smoke
  • 83
« Reply #6 on: July 25, 2011, 10:46:26 pm »
not a chance
this is true.  I already had my tire of, so...
2001 TDI
An Oldvolks Home
Reply #7July 25, 2011, 10:49:38 pm
« Reply #7 on: July 25, 2011, 10:49:38 pm »
yea, well, if its already off, it just makes it that much easier.
Reply #8July 26, 2011, 07:00:36 am
« Reply #8 on: July 26, 2011, 07:00:36 am »
I tried to get the plug out last time I did the fluid.. I had a nut and bolt locked down on one another.. sheared the head off a haevy grade bolt..
THAT is the only reason i would pay someone else to do it LOL
Reply #9July 26, 2011, 08:15:28 am
Grey_Smoke
  • 83
« Reply #9 on: July 26, 2011, 08:15:28 am »
They are in there tight.  but the wheel bolt is long enough that you can fit wrench on it, and still seat it all the way into the plug.
2001 TDI
An Oldvolks Home
Reply #10July 26, 2011, 08:21:25 am
« Reply #10 on: July 26, 2011, 08:21:25 am »
You turned it out with just a wrench? Lol, I ended up draining mine out the end of the 5th :) lol
Reply #11July 26, 2011, 10:10:21 am
« Reply #11 on: July 26, 2011, 10:10:21 am »
how did you completely drain it thru the 5the end plug? tilt the car on its side about 45*?
Reply #12July 26, 2011, 10:58:37 am
Grey_Smoke
  • 83
« Reply #12 on: July 26, 2011, 10:58:37 am »
I used a REALLY big wrench.  :P
2001 TDI
An Oldvolks Home
Reply #13July 26, 2011, 11:58:18 am
« Reply #13 on: July 26, 2011, 11:58:18 am »
17mm headed bolt.. 2 nuts locked together on bolt = tool..
pull speedo cable add 2 quarts..
that simple sir.. screw side fill plug..
Reply #14July 26, 2011, 12:01:18 pm
« Reply #14 on: July 26, 2011, 12:01:18 pm »
I used the bolt with two nuts trick, sheared the head off an 10.8 :o.
Also I drained it with the 5th end pointing straight down :o *90 ;)
