Author Topic: Cylinder 3, needle lift sensor  (Read 4124 times)
January 28, 2006, 01:44:27 pm
DieselMonkey
  • 124
« on: January 28, 2006, 01:44:27 pm »
Guys,
I've got a little project and before I go any further, I need to know what function the needle lift sensor on cylinder 3 has and what effect it has on the ECU. What information does it receive and in what way.
Any help would be very much appreciated.
Regards, DM
Reply #1January 29, 2006, 02:28:40 pm
RedRotors
  • 734
    • http://www.mikrotuning.com
Re: Cylinder 3, needle lift sensor
« Reply #1 on: January 29, 2006, 02:28:40 pm »
Quote from: "DieselMonkey"
Guys,
Regards, DM
The ECU need the 3rd NLS injector as a ref. mark for the timing.. The ECU can also use it as a ref for the RPM in case of crank sensor malfunction..
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
