Author Topic: Difference between Hydraulic and Solid Cam?  (Read 3807 times)
July 19, 2011, 11:10:06 am
silentdub
  • 135
« on: July 19, 2011, 11:10:06 am »
I know the difference actually, but I guess my question would be, Is there a reason to use one and not the other?
All of the previous motors I built were all hydraulic, especially the older V8's.
Is there a reason for one verse the other on a 1.6 N/A? Other than being quieter.
Reply #1July 19, 2011, 12:36:12 pm
Re: Difference between Hydraulic and Solid Cam?
« Reply #1 on: July 19, 2011, 12:36:12 pm »
well, solid lifters need the valves adjusted, hydro lifters dont need adjustment. and you can turn a few more rpms using a solid lifter head on a gasser engine. our engines dont care, the head is not the limiting factor for rpms, the pump is..
Reply #2July 19, 2011, 08:31:31 pm
« Reply #2 on: July 19, 2011, 08:31:31 pm »
the lobe is different... solid lifter much much longer.. and bigger diameter too..
Reply #3July 19, 2011, 08:34:32 pm
« Reply #3 on: July 19, 2011, 08:34:32 pm »
I believe the valve lift is the same though.
Reply #4July 19, 2011, 08:38:57 pm
« Reply #4 on: July 19, 2011, 08:38:57 pm »
LOL.. hydro lifter is "longer" so i bet it locks up with non hydro cam first..
people regrind solid cams for performance hydro cams due to the extra metal.. will not work.. and a hydro cam in a non hydro head would require some serious shims to make up the differance..
if you broke your hydro cam.. and are looking for a solution.. you can send delta cams in tacoma washington a solid cam to convert into hydro.. 15 years ago it was a 100$ solution..
Reply #5July 20, 2011, 08:52:59 am
silentdub
  • 135
« Reply #5 on: July 20, 2011, 08:52:59 am »
Thanks for the info. I don't need a new cam or want to change anything, I just wanted to know the difference on these little guys.
I think most SB V8's go with hydro unless it is a serious race engine. Well, most are roller now anyway.
I did notice that when I pulled the lifters, a few of them were in 2 pieces. The top part came away from the skirts.
Reply #6July 20, 2011, 09:08:09 am
Mark(The Miser)UK
  • 1557
« Reply #6 on: July 20, 2011, 09:08:09 am »
They all do that! That is the bit held under oil vaccuum that you change to alter valve gap, and is called a shim. Absent in the hydraulic version ;D
Mark-The-Miser-UK
Reply #7July 20, 2011, 09:13:13 am
silentdub
  • 135
« Reply #7 on: July 20, 2011, 09:13:13 am »
Gotcha, yeah, its not really a lifter in the traditional sense.
Reply #8July 20, 2011, 09:53:13 am
Mark(The Miser)UK
  • 1557
« Reply #8 on: July 20, 2011, 09:53:13 am »
Cam follower perhaps.
Mark-The-Miser-UK
Reply #9July 20, 2011, 10:31:51 am
silentdub
  • 135
« Reply #9 on: July 20, 2011, 10:31:51 am »
follower, shim...... I guess I am showing my age when I say lifters, not many motors these days are OHV engines.
Reply #10July 20, 2011, 11:27:01 am
Mark(The Miser)UK
  • 1557
« Reply #10 on: July 20, 2011, 11:27:01 am »
Rockers, push rods and screw adjusters....
And grease nipples, but that's another story  :o
Mark-The-Miser-UK
