Author Topic: Intercooler kit for a MKII Jetta?  (Read 11029 times)
July 04, 2011, 09:00:07 am
VW_Commuter
  • 355
« on: July 04, 2011, 09:00:07 am »
Has anyone found a good intercooler kit on the web for a MKII Jetta?  I'd like to find one that comes will all of the needed pipes, couplers, and the intercooler and not have to try and source everything separeately.  I saw this intercooler kit on Amazon?  The dimensions are 28"x5.5"x2.5" with a 2" inlet/outlet.  I like the looks of this one due to the compactness of the intercooler itself but there is also a kit with 2.5" inlet/outlet but the intercooler is 27"x6"x2.5".
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #1July 04, 2011, 09:03:45 am
Re: Intercooler kit for a MKII Jetta?
« Reply #1 on: July 04, 2011, 09:03:45 am »
mk2 big bumper? idk if your gonna find a kit specifically for the car.. a universal kit off ebay will probably work tho..
Reply #2July 04, 2011, 09:12:16 am
VW_Commuter
  • 355
« Reply #2 on: July 04, 2011, 09:12:16 am »
Yeah, MKII big bumpers.  I know that others have stuffed big intercoolers inside of a MKII with big bumpers and just wanted more info.   A big question I have is do I go with the 2" or 2.5" inlet/outlet intercooler.
Greg
Reply #3July 04, 2011, 09:27:45 am
« Reply #3 on: July 04, 2011, 09:27:45 am »
i would go 2"
that keeps your tubing smaller, for less volume to fill.. the bigger the piping, the more lag you get because the turbo has a bigger area to pressurize..
2" will be more than adequate..
Reply #4July 04, 2011, 10:12:22 am
« Reply #4 on: July 04, 2011, 10:12:22 am »
http://www.vwdiesel.net/forum/index.php?topic=16572.315
I have small bumpers. There wasn't really anything left of my core support on the back side, I had to weld support on the front side. A smaller intercooler would fit a ton better. Just be prepared to take the core support out and put back in 53 times to get it to fit right.
Reply #5July 04, 2011, 02:47:03 pm
VW_Commuter
  • 355
« Reply #5 on: July 04, 2011, 02:47:03 pm »
I was thinking that the 28"x5.5"x2.5" would be easier to stuff inside the bumper.  I think the 5.5" height will be easier to fit and the 28" length looks pretty good but then I saw this intercooler on the CXRacing.com site and it's dimensions are 25.5"x5.5"x2.5" with 2" inlet/outlet which is even more compact which might make it even easier to fit.  Unfortunately they don't seem to offer the smaller intercooler in a kit form.
Greg
Reply #6July 04, 2011, 04:53:03 pm
« Reply #6 on: July 04, 2011, 04:53:03 pm »
You will want the 28 anyway. I was able just to hook my 90 degree elbows up and miss the core support structure to head back to the engine. Narrower and you may have to have a stub piece in between. Either way I think an intercooler is better than no intercooler.
Reply #7July 04, 2011, 09:09:27 pm
VW_Commuter
  • 355
« Reply #7 on: July 04, 2011, 09:09:27 pm »
Thanks for that insight on intercooler length.  I'll go with the 28"x5.5"x2.5" kit then.  Did you see a decrease in max boost pressure due to temperature reduction of the charge air?
Greg
Reply #8July 04, 2011, 11:07:36 pm
Thezorn
  • 381
« Reply #8 on: July 04, 2011, 11:07:36 pm »
Very minimally. With 15 psi intercooled boost you will have more power then with 20 psi non intercooled boost. I have this exact same kit, I got a couple extra 45* couplers to go with it, they make ssembley alot easier. Over all its a good kit but the T-Bolt clamps you get with it are garbage, they snap with the tiniest bit of torque.
Compounded 93 AAZ
Reply #9July 05, 2011, 01:28:57 pm
« Reply #9 on: July 05, 2011, 01:28:57 pm »
What is the effect on your mileage?
Reply #10July 05, 2011, 05:14:24 pm
Thezorn
  • 381
« Reply #10 on: July 05, 2011, 05:14:24 pm »
Probabley worse since I had a bit more power, my foot was alot heavier.
If you drove normally though, I cant see it changing anything drastically.
Compounded 93 AAZ
Reply #11July 05, 2011, 05:35:09 pm
VW_Commuter
  • 355
« Reply #11 on: July 05, 2011, 05:35:09 pm »
Any suggestions on where to get better T-Bolt clamps from?
Greg
Reply #12July 05, 2011, 06:17:12 pm
Reply #13July 05, 2011, 11:01:07 pm
VW_Commuter
  • 355
« Reply #13 on: July 05, 2011, 11:01:07 pm »
Thanks.
Greg
Reply #14July 06, 2011, 08:53:46 pm
Thezorn
  • 381
« Reply #14 on: July 06, 2011, 08:53:46 pm »
Any industiral store or even hydrolic hose/fittings shop usually sells them. Goos ones are a bit pricey though, mine were 7 bucks a piece
Compounded 93 AAZ
