Author Topic: valve/piston clearance issue  (Read 5559 times)
July 03, 2011, 06:37:48 pm
ienjoysnails
  • 19
« on: July 03, 2011, 06:37:48 pm »
erase
« Last Edit: August 13, 2011, 04:34:20 pm by ienjoysnails »
Reply #1July 05, 2011, 04:56:55 pm
dieselweasel
  • 312
Re: valve/piston clearance issue
« Reply #1 on: July 05, 2011, 04:56:55 pm »
Did the machine shop do any work to the head besides remove stuck injectors?  Did they mill the surface?  I'm concerned about the different valve opening distances...perhaps they made an error re-assembling the head?  I'd be inclined to remove the valves and check everything...
Reply #2July 05, 2011, 07:06:55 pm
ienjoysnails
  • 19
« Reply #2 on: July 05, 2011, 07:06:55 pm »
the head was only off to facilitate easier removal of the stuck injectors.  nothing was done to the head itself while at the machine shop beside being manhandled
Reply #3July 05, 2011, 07:36:20 pm
« Reply #3 on: July 05, 2011, 07:36:20 pm »
I would guess that your timing mark is off????
Or the shop bent your valves getting the injectors out.
Reply #4July 05, 2011, 08:14:46 pm
« Reply #4 on: July 05, 2011, 08:14:46 pm »
Good call, probably thumped it down on the work bench and a valve landed on a socket or something.
Reply #5July 05, 2011, 08:33:58 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #5 on: July 05, 2011, 08:33:58 pm »
'locked the crank'
How exactly do you lock the crank in place on a 1Z? FWIW, NEVER put the crank at TDC when installing a head with cam installed. I always put the pistons in the middle of their stroke when I put a head on. Marks can lie to you..
Is it bad that I looked at your location when you said you had to take the head to a machine shop to get the injectors removed?
West coaster here..
Reply #6July 06, 2011, 05:56:20 am
ienjoysnails
  • 19
« Reply #6 on: July 06, 2011, 05:56:20 am »
i "locked" crank using a strap wrench and locking plier.  very backyard mechanic but it works.  i'll make sure not to install head again while at tdc
when the head is off i'm able to verify tdc by looking at the pistons in their stroke, and it perfectly matches up with the marking on flywheel, so thats good.
what might cause a valve to open excessively far?  seems like some of them open a tiny bit and some open alot.
Reply #7July 06, 2011, 07:02:53 am
« Reply #7 on: July 06, 2011, 07:02:53 am »
PICS
Cam lobes could be messed up or bent valves not letting it come all the way up. I would try to rotate the camshaft with the head off the car and see what you get.
Reply #8July 13, 2011, 11:07:51 am
ienjoysnails
  • 19
« Reply #8 on: July 13, 2011, 11:07:51 am »
erase
« Last Edit: August 13, 2011, 04:34:00 pm by ienjoysnails »
Reply #9July 13, 2011, 12:41:43 pm
rallydiesel
  • 1880
« Reply #9 on: July 13, 2011, 12:41:43 pm »
Looks like the oil leaked out of the followers causing different valve lifts. It will go back to normal after a few cranks.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
