Author Topic: Headgasket failures  (Read 4519 times)
June 29, 2011, 06:15:01 pm
  • 1739
Headgasket failures
« on: June 29, 2011, 06:15:01 pm »
Has anybody ever have to change a headgasket on a stock TDI? I don't think i've ever seen or changed one just for that
Reply #1June 29, 2011, 07:38:01 pm
vanagonturbo
  • 639
    • Fine Tuning
Re: Headgasket failures
« Reply #1 on: June 29, 2011, 07:38:01 pm »
Nope. Why do you ask? FWIW, I havent had to change a head gasket on an OBD2 ABA either.
Reply #2June 30, 2011, 06:34:12 am
  • 1739
« Reply #2 on: June 30, 2011, 06:34:12 am »
Just asking.  i know that some engines go through headgaskets more than others-like the 1.6 ACC gasser, plus the odd 1.6 IDI's. It came to mind because I'm about to convert a GLX to TDI and the engine i'm using has over 430,000 kms, and compression is well above what you would except from 90 % of engines out there. Thought that I would change the HG while replacing all the other seals, but realized why change it for no reason.
Reply #3June 30, 2011, 10:33:06 am
« Reply #3 on: June 30, 2011, 10:33:06 am »
shouldnt fix something that aint broke..
that could be asking for problems..
Reply #4July 06, 2011, 05:20:33 am
BigVWman
  • 332
« Reply #4 on: July 06, 2011, 05:20:33 am »
I have changed three but for other reasons(one preventive when doing swap 2&3 were for broken tb's). No big deal, nearly same process as na except timing.I certainly wouldn't change it just because of mileage in a running car. Heck some of the big diesels go a million without ever having heads off! It will tell you when its time to change!
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #5July 06, 2011, 06:06:57 am
  • 1739
« Reply #5 on: July 06, 2011, 06:06:57 am »
My reason for asking was just to prove to myself how much better and reliable these engines are. I was kinda thinking out loud because I don't know of one ever failing
Reply #6July 09, 2011, 05:34:01 pm
Quantum TD
  • 1195
« Reply #6 on: July 09, 2011, 05:34:01 pm »
I did one on a 1998 TDI. It was definitely bad.
Reply #7July 09, 2011, 11:40:24 pm
RadoTD
  • 513
    Stage WTF
« Reply #7 on: July 09, 2011, 11:40:24 pm »
Doesn't that simply defy half of everything this forum is about? haha
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #8July 10, 2011, 10:54:32 am
« Reply #8 on: July 10, 2011, 10:54:32 am »
i think its basically agreed upon that replacing a good head gasket is bad practice, unless the turbo thats about to go on your engine is a big scary bully, and wont play nice with that new head gasket..
Reply #9July 10, 2011, 12:33:00 pm
« Reply #9 on: July 10, 2011, 12:33:00 pm »
I thought that and the timing belt were annual maintenance....
