Author Topic: FS: 80 Caddy, 81 Gas Rabbit 2dr -Picture Heavy-  (Read 4456 times)
June 19, 2011, 04:09:34 pm
camboscams
  • 324
« on: June 19, 2011, 04:09:34 pm »
So here it is, theres so much stuff here if you see anything that strikes your fancy let me know. If you want either the car or the caddy i'm willing to sell as a whole.
The car: Its a gasser i've never run it. the interior is rough but the body is pretty straight. if you want more pictures just pm me
The caddy: its got a broken camshaft thanks to the previous owner attempting to tighten the camshaft bolt without the proper tool.
There are tons of NA 1.6 and some 1.5 parts as well, i know thats vague so i apologize
If you want any more information or pictures just let me know!
Thanks, Cambo
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #1June 24, 2011, 04:33:13 am
camboscams
  • 324
Re: FS: 80 Caddy, 81 Gas Rabbit 2dr -Picture Heavy-
« Reply #1 on: June 24, 2011, 04:33:13 am »
Im not looking to get rich here and i know i didn't include prices, but i'm pretty much trying to get out from under the title transfer costs from when i bought it so make me any offer
Reply #2June 29, 2011, 10:31:52 pm
79rabbit4dr
« Reply #2 on: June 29, 2011, 10:31:52 pm »
 ??? the tailgate (even all rusted) and the tail light assemblies are the only things I see worth keeping/selling. The rest I'd take to the metal recyclers, honestly.
Reply #3June 30, 2011, 09:15:36 am
« Reply #3 on: June 30, 2011, 09:15:36 am »
pull that mk2 pump off the truck before you get rid of it..
i really wish i had a mk2 pump, for the out bolt pedestal..
Reply #4June 30, 2011, 09:43:55 am
camboscams
  • 324
« Reply #4 on: June 30, 2011, 09:43:55 am »
yea that might be its next stop unless no one here shows any interest.
pull that mk2 pump off the truck before you get rid of it.. i really wish i had a mk2 pump, for the out bolt pedestal..
if you want it let me know and i can look up some shipping numbers
Reply #5June 30, 2011, 09:29:50 pm
« Reply #5 on: June 30, 2011, 09:29:50 pm »
R.O.R.  for the grand sum of about 2 bucks you can make that out bolt extension yourself.  One nut and bolt from the hardware store.  12mm 1.25 pitch I think.  Drill the bolt down the center and solder the nut on the top.  Works fine.  See here:
I had to use thicker copper washers on either side of the OUT bolt to get it to seal tight.  The OUT bolt was bottoming out in the nut and I didn't want to file off the bolt as it has the screen in it.  So far this little bugger is working well to monitor the IP pressure.
Reply #6July 01, 2011, 10:23:20 am
« Reply #6 on: July 01, 2011, 10:23:20 am »
well, if Cambo doesnt want much for the whole pump, i will go that route.. you can never have enough pumps..
Reply #7July 01, 2011, 08:20:40 pm
« Reply #7 on: July 01, 2011, 08:20:40 pm »
true dat
