Author Topic: load reduction relay  (Read 4119 times)
May 24, 2011, 12:39:54 pm
jaysen71581
  • 211
    Hagerstown, MD
« on: May 24, 2011, 12:39:54 pm »
I need a pic of the location for the  load reduction relay for my rabbit, i think its bad..
Reply #1May 24, 2011, 01:32:26 pm
Quantum TD
  • 1195
Re: load reduction relay
« Reply #1 on: May 24, 2011, 01:32:26 pm »
Should be bottom left or right. It's a small tin-relay. If you pull the relay, it will say what it is on the panel below it. In this case, it will say "X-Relay".
Reply #2May 24, 2011, 05:50:39 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #2 on: May 24, 2011, 05:50:39 pm »
I found that and i replaced it with the relay in the horn spot and i still got nothing, no wipers and no blower motor, i know they work they were both working...
Reply #3May 24, 2011, 07:37:00 pm
Quantum TD
  • 1195
« Reply #3 on: May 24, 2011, 07:37:00 pm »
The only thing I can think of is blown fuses either in the fuse panel, or one of the 2-3 fusible links in the engine bay near the battery. Or, one of the ground wires behind the fuse panel came unscrewed. I'd check the ground. That would explain why both don't work.
Lastly, you could try an ignition switch.
Reply #4May 24, 2011, 07:45:37 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #4 on: May 24, 2011, 07:45:37 pm »
fuseable links in the engine bay??? I no longer have the fusable link for the GP's, ill get a new relay tomorrow and try that, my fuses are good ive tested them,
« Last Edit: May 24, 2011, 07:49:16 pm by jaysen71581 »
Reply #5May 24, 2011, 08:30:31 pm
Quantum TD
  • 1195
« Reply #5 on: May 24, 2011, 08:30:31 pm »
If you have a USA Rabbit or Pickup, there are fusible links in the wiring harness. There should be 2-4 depending on the year. Earlier cars had fewer. There's part of the RED wires that are exposed from the harness. They connect to their plain-copper equivalents with BLACK rubber fused-rubber. You'll notice that the wire on one side of the black rubber "bullets" are weaker and more-pliable than on the other. The weak side is designed to burn up in case of a voltage overload, rather than sending power to the cabin and causing an electrical fire.
Electrical fires=common on aircooled
Not so common on USA Rabbits.
Reply #6May 25, 2011, 05:17:42 am
jaysen71581
  • 211
    Hagerstown, MD
« Reply #6 on: May 25, 2011, 05:17:42 am »
Thats new to me, ive never noticed anything like that in my harness, it is a USA rabbit, hmm ill check it out though thanks..
Reply #7May 25, 2011, 08:48:11 am
« Reply #7 on: May 25, 2011, 08:48:11 am »
there up by the battery. they all have them.
Reply #8May 25, 2011, 01:13:13 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #8 on: May 25, 2011, 01:13:13 pm »
Ill pop the hood when i get home, any chance you can snap a pic for me so i have a reference to go off of? :-\
Reply #9May 26, 2011, 06:14:17 am
jaysen71581
  • 211
    Hagerstown, MD
« Reply #9 on: May 26, 2011, 06:14:17 am »
Ok well i got kinda good news, i grabbed a 40amp relay this morning from Autozone and my blower fan came on but still no wipers..
Reply #10May 26, 2011, 07:02:04 am
Mark(The Miser)UK
  • 1557
« Reply #10 on: May 26, 2011, 07:02:04 am »
Ignition switch fault?
Mark-The-Miser-UK
Reply #11May 26, 2011, 11:25:27 am
« Reply #11 on: May 26, 2011, 11:25:27 am »
yea, thats kinda weird, wipers usually always work, even without the relay installed..
Reply #12May 26, 2011, 04:03:25 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #12 on: May 26, 2011, 04:03:25 pm »
Hmmm got me too on this one, RAINX lol  ;D
Reply #13May 26, 2011, 08:33:29 pm
sdwarf36
  • 159
« Reply #13 on: May 26, 2011, 08:33:29 pm »
Well.. there was that time my Jetta's headlight switch started smoking  :(...while taking the wife out to dinner for her birthday  :'(......
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
