Author Topic: MK3 output shaft size?  (Read 4563 times)
May 23, 2011, 11:00:32 am
  • 1739
« on: May 23, 2011, 11:00:32 am »
Does anyone know what size the diff output shafts are on a 98 TDI ? I thought they were the smaller size, but Vag-cat lists them as 100mm, which would be perfect as  i have a GLX as a donor car to drop my TDI drive train into. That way i don't have to bother  about changing the flanges to match the drive  shafts.
Reply #1May 23, 2011, 11:40:50 am
Re: MK3 output shaft size?
« Reply #1 on: May 23, 2011, 11:40:50 am »
TDI should have the CTN trans yes? 100mm output flanges.
btw, im responding to your PM right now :P lol
Reply #2May 24, 2011, 06:51:09 am
BigVWman
  • 332
« Reply #2 on: May 24, 2011, 06:51:09 am »
yep trans should be 100mm but if your glx transplant recipient was a vr6 it would have been 108 iirc.
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #3June 06, 2011, 05:40:07 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #3 on: June 06, 2011, 05:40:07 am »
all 02a Transmissions are 100mm
on the 02J the 2L and TDI have 100mm and the Vr6 and 20V have 108mm
Reply #4June 06, 2011, 06:34:22 am
  • 1739
« Reply #4 on: June 06, 2011, 06:34:22 am »
Okay, so I hope i'll be able going to swap over the flanges- if they install the same way,
Reply #5June 07, 2011, 08:44:22 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #5 on: June 07, 2011, 08:44:22 am »
what is there to swap? If you have a mk3 tdi transmission (02A transmission family with a code of CTN) then you have 100mm which is the same size as the mk3 Vr6 (02a transmission family with a code of CCM) output flanges
« Last Edit: June 07, 2011, 08:47:54 am by G60ING »
Reply #6June 30, 2011, 02:09:36 pm
  • 1739
« Reply #6 on: June 30, 2011, 02:09:36 pm »
Started the swap. They are indeed the same. Saves me a little work. Worse thing so far has been removing the throttle pedal.
Reply #7June 30, 2011, 02:15:29 pm
« Reply #7 on: June 30, 2011, 02:15:29 pm »
clutch master is worse...
Reply #8June 30, 2011, 04:41:03 pm
  • 1739
« Reply #8 on: June 30, 2011, 04:41:03 pm »
No problem here, donee car already has, thankfully.
