1) accessory bracket
2) serpentine idler
3) serpentine crank pulley (will this bolt to the 1.6 balancer?)
No, it will bolt to the crank gear4) serpentine 90 A alternator ( do I need a clutching pulley, and if so, why?)
See Libby's answer5) serpentine A/C compressor (need new freon lines -- not same as 1.6 compressor?)
correct, not the same6) water pump pulley (is it serpentine? If v belt, what drives it?)
With AC it is V-belt driven off the crank. It shares the belt with the PS pump7) ps pump (will the 1.6 unit work? What drives it?)
I forget how I made it work. It is driven by the crank with the WP
Nuts and bolts. They are very different than what you have now
9) serp belt
