Author Topic: Intake Mods  (Read 7900 times)
Reply #15April 21, 2011, 09:40:44 am
Re: Intake Mods
« Reply #15 on: April 21, 2011, 09:40:44 am »
I dunno about that, they were vented back to the intake(like they are on almost all cars for a very long time) because it is cleaner, and there is nothing for the stupid owner to clean/empty.
the valve guides are self lubricating bronze, no need for oil to lube them.
-Owen
no, someone else has told me this too.. i really hope someone else chimes in with where they found that info.. im not smoking crack, ive heard about the VW CCV system lubing the valves before..
Reply #16April 21, 2011, 09:55:11 am
truckinwagen
  • 1895
Re: Intake Mods
« Reply #16 on: April 21, 2011, 09:55:11 am »
its a common misconception, propagated mostly by the G60 folks.
83 Opel Kadett Diesel
Reply #17April 21, 2011, 09:57:18 am
Re: Intake Mods
« Reply #17 on: April 21, 2011, 09:57:18 am »
no dude, everyone who ive heard that from, is off this forum..
watch, nobody is gonna back me up on this one. now im gonna be standing here, with everyone lookin at me like im smokin crack..
Reply #18April 21, 2011, 10:23:51 am
jseeley
  • 106
Re: Intake Mods
« Reply #18 on: April 21, 2011, 10:23:51 am »
85 Golf Diesel 1.6 NA 240K miles? (odometer broken)
87 Cabriolet 1.8 Gasser 104K miles
05 Golf 2.0 Gasser 66k miles
03 Jetta Wagon TDI 112k Miles
Reply #19April 21, 2011, 10:44:54 am
Re: Intake Mods
« Reply #19 on: April 21, 2011, 10:44:54 am »
http://en.wikipedia.org/wiki/Crankcase_ventilation_system
im not talking about CCV systems in general..
im talking about the CCV system on a VW IDI Diesel.. ive heard from many reliable people that the oil mist in the blow by is to help lube the valves..
Reply #20April 21, 2011, 01:06:19 pm
mtrans
  • 308
Re: Intake Mods
« Reply #20 on: April 21, 2011, 01:06:19 pm »
About intake
I like it,but I always think that wire must be inside tube if it`s rubber,for vacum
I`ll improve my English
Reply #21April 21, 2011, 01:26:40 pm
Re: Intake Mods
« Reply #21 on: April 21, 2011, 01:26:40 pm »
About intake
shop vac hose works great.. its the right size, and its made for vacuum..
Reply #22April 21, 2011, 05:23:42 pm
jseeley
  • 106
Re: Intake Mods
« Reply #22 on: April 21, 2011, 05:23:42 pm »
About intake
I used aircraft tubing; It is supported with wire on the inside.
http://www.aircraftspruce.com/menus/ap/ducting.html
Reply #23April 21, 2011, 05:47:45 pm
Re: Intake Mods
« Reply #23 on: April 21, 2011, 05:47:45 pm »
I have heard from 2 different VOA mechanics and Dakotakid on this forum that VW designed the oil in the intake for an upper cylinder lube.
There you go ROR.
Reply #24April 21, 2011, 06:47:50 pm
Re: Intake Mods
« Reply #24 on: April 21, 2011, 06:47:50 pm »
I think it actually says that in the 1.5L SAE paper.  Yes, the CC vapours are vented to the intake to save planet earth, but a happy benefit (according to VW's engineers) is that it provides lubrication to the intake valves and upper cylinder walls.
Reply #25April 21, 2011, 07:10:14 pm
Re: Intake Mods
« Reply #25 on: April 21, 2011, 07:10:14 pm »
So the exhaust valves don't need lube but the intakes do?
The upper cylinder thing makes perfect sense.
Reply #26April 21, 2011, 09:08:26 pm
blackdogvan
  • 574
Re: Intake Mods
« Reply #26 on: April 21, 2011, 09:08:26 pm »
why even modify it? does it need to be deleted for your particular style of intake to work? the breather was vented into the intake manifold so the blow by gasses could lubricate the intake valves..
Now you're just making things up...
1991 Vanagon 1.9 mTDI
Reply #27April 22, 2011, 11:17:27 am
Re: Intake Mods
« Reply #27 on: April 22, 2011, 11:17:27 am »
i hope your being sarcastic? lol.
Reply #28April 24, 2011, 12:23:42 pm
blackdogvan
  • 574
Re: Intake Mods
« Reply #28 on: April 24, 2011, 12:23:42 pm »
Thats an ancient old wives tale invented by techs to get complaining car owners off their back about oil in the intake tract. Lube the valves... thats rich. ::) ;D
« Last Edit: April 24, 2011, 09:09:05 pm by blackdogvan »
Reply #29April 24, 2011, 01:13:07 pm
  • 4553
Re: Intake Mods
« Reply #29 on: April 24, 2011, 01:13:07 pm »
Getting back to original concept here.  I used metal dryer vent hose, 3 inch from the front of the air box on mine.  I have the other not so great, NA 1.6 set up.  The metal pipe is able to be formed into an oval that gently returns to a full 3 inch circle as it snakes over the alternator.  At that point it attaches to a 4 inch to 3 inch reducer that I custom cut and filed in place on the left side of the radiator.  That gives me 4 inch surface just behind the grill to a 2.5 inch oval at the box.  Looking for that ram air pressure.
All .5 lbs of it.
Pipe held on with plastic pull ties.  Looks good. but louder than dense plastic weenie tube.  Thinking of a sound wrap on it, Maybe, between speaker box effect of intake box and megaphone style inlet it is a weird noise at idle.  After leaving a light it is back to standard diesel buzz.
