Author Topic: Wanted: good used transmission  (Read 9164 times)
April 19, 2011, 09:34:40 am
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« on: April 19, 2011, 09:34:40 am »
Im looking for a good used transmission for my 83 jetta 1.6 TD
heres the codes that were on the transmission
103 373 f2br
FN 2805 2 020    301 103 H
Thanks guys
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #1April 19, 2011, 11:10:44 am
Re: Wanted: good used transmission
« Reply #1 on: April 19, 2011, 11:10:44 am »
so, basically any Fx trans will work for you, besides the FK and the like, out of GTIs.. you want a nice long ratio trans..
http://scirocco.org/gears/
any of the trannies from the first 3 lines would be a direct swap. some mk2 trannies will even swap in without too much work.
Reply #2April 19, 2011, 02:31:25 pm
79rabbit4dr
« Reply #2 on: April 19, 2011, 02:31:25 pm »
<hijack>
Did you just get the 83? Is it all factory? What did you pay? Can you send me/post pix?
Just trying to learn more about these babies as I recently acquired one and was promptly told they are super rare, thanks!
</hijack>
Reply #3April 19, 2011, 05:16:18 pm
dankcorey22
  • 379
    Cummins!
« Reply #3 on: April 19, 2011, 05:16:18 pm »
So FX, will work i have no clue about transmissions and the ratio things. I just need to find one with a taller 5th or the same as the trans i got now.
I dont want to risk putting a trans in there and then going on the highway at 3500 RPM 70 MPH lol
Reply #4April 19, 2011, 05:20:06 pm
dankcorey22
  • 379
    Cummins!
« Reply #4 on: April 19, 2011, 05:20:06 pm »
<hijack>
</hijack>
Yes 83 Code CY its all factory without any rust. I paid $375 for it and drove it 3000Miles with out doing anything to it! Cant believe that.
I just decided to rebuild it. just for the hell of it. But rings were kinda bad. used oil. Yes they are super rare.
My build thread: http://www.vwdiesel.net/forum/index.php?topic=26384.msg212432#msg212432
enjoy!  ;)
Now need a trans!
Reply #5April 20, 2011, 01:30:07 pm
« Reply #5 on: April 20, 2011, 01:30:07 pm »
no dude.. there is no FX code trannies.. i said Fx (replace X with proper letter of trans code) there are F series trannies, (FF, FN, FJ, FH, FO) any of those are mk1 trannies with long gears..
or you could find an ACH/ACN out of a mk2 car, wont be too much hassle to swap it in..
Reply #6April 20, 2011, 05:29:13 pm
dankcorey22
  • 379
    Cummins!
« Reply #6 on: April 20, 2011, 05:29:13 pm »
Alright man thanks i know what your saying now. They shouldnt be to hard to source out a good used one.
But if anyone know where to get one or if they have one let me know ill take it off anybodies hands!
Reply #7April 20, 2011, 06:00:09 pm
« Reply #7 on: April 20, 2011, 06:00:09 pm »
I am getting a few used ones off of Myke_W . He has a FS thread on here I am getting the FF, ATA, and another one I can't remember. Maybe he can ship to you?
Reply #8April 20, 2011, 10:11:39 pm
Baron VonZeppelin
« Reply #8 on: April 20, 2011, 10:11:39 pm »
LKQ in Durham has 5 mk2's on hand right now.
That was report from Wolfsburged on Sunday.
All gassers - and think all had engine/trans.
I haven't been to GSO U-Pull recently - but need to go soon and take inventory.
You'll want 85 or 86 only - if from mk2.
And double check for the multi-provision mounts on those.
NCDubs.org can probably help you out too.
Reply #9April 21, 2011, 03:15:32 am
Patrick
  • 1034
« Reply #9 on: April 21, 2011, 03:15:32 am »
There's other options too, I had a 7A in a mk 1 gas jetta (factory installed trans), nice gearing for a diesel, .71 overdrive.
Reply #10April 21, 2011, 05:38:14 am
ilikevwdiesel
  • 1202
« Reply #10 on: April 21, 2011, 05:38:14 am »
7A is the best transmission for that car. only found in 84 Jetta and Rabbit diesel and 1.7 gas cars. No Sciroccos, GTI, GLI or convertible models, they have close ratio. Otherwise get an FN or FF
My Bio
Reply #11April 21, 2011, 01:38:07 pm
dankcorey22
  • 379
    Cummins!
« Reply #11 on: April 21, 2011, 01:38:07 pm »
So does the 7A bolt up without any mods? There only found in 84 gassers? no anyother gassers? I know where some MK1 gassers are
Reply #12April 21, 2011, 01:40:16 pm
dankcorey22
  • 379
    Cummins!
« Reply #12 on: April 21, 2011, 01:40:16 pm »
The mk2 trans will bolt up correctly? whats the code for those?
I might go to GSO u-pull-it in May ill keep you posted when i go and what i see.
Reply #13April 21, 2011, 01:43:43 pm
ilikevwdiesel
  • 1202
« Reply #13 on: April 21, 2011, 01:43:43 pm »
you can use any 5 spd. transmission from any 80 to 98 golf jetta rabbit or pickup as long as it has a cable clutch. They're called 020 transmissions by VW cause that's what any part number for the unit starts with - 020. Some use different clutch discs but otherwise they all interchange. For your application though the 7A is probably the best because of the gear ratios VW put in that unit.
if I were you I would not get a gasser trans your car will be numb off the line. Make sure the trans you get has a 3.89 or 3.94 final drive ratio.
« Last Edit: April 21, 2011, 01:49:32 pm by ilikevwdiesel »
My Bio
Reply #14April 21, 2011, 02:16:49 pm
« Reply #14 on: April 21, 2011, 02:16:49 pm »
unless you got a turbo car, then a 3.67 final drive is SWEET!
around the city, a close ratio with 3.67's rocks. on the freeway, a long ratio with 3.67s rocks..
its all about personal preference, i like the 3.67 gears myself, but i do alot of driving at 55 or more mph..
