Author Topic: 1.6 Non Turbo 8 Valve SOHC Diesel Head  (Read 5247 times)
April 15, 2011, 11:17:50 am
GregMottin
  • 4
« on: April 15, 2011, 11:17:50 am »
I have a 1.6 Non Turbo 8 Valve SOHC Diesel Head I just posted on Ebay for a starting bid of .99 cents.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=110675232153&viewitem=&sspagename=STRK%3AMESELX%3AIT
I have years of experience working as a mechanic, and have worked in machine shops, but I am not  VW or Diesel guy. This head belonged to a friend who used to have a VW Pick up. I wonder if anyone more knowledgeable than myself can help me make sure the description is accurate.
Thanks for your time,
Greg
925-519-8781
« Last Edit: April 15, 2011, 02:17:07 pm by GregMottin »
Reply #1April 15, 2011, 02:16:55 pm
Re: 1.8 Non Turbo 8 Valve SOHC Diesel Head
« Reply #1 on: April 15, 2011, 02:16:55 pm »
You spelled "diesel" wrong in the title. If you can change that you should.
Also, you could add that it is a mechanical lifter head to the title.
The cracking between the valves is nothing to worry about (usually). It's only if the cracks are too wide that it can be a problem. I think the Bentley (service manual) specs it at the width of a penny. It's always a good idea to pressure test the head before investing in a rebuild because of this.
Reply #2April 15, 2011, 02:24:50 pm
GregMottin
  • 4
Re: 1.6 Non Turbo 8 Valve SOHC Diesel Head
« Reply #2 on: April 15, 2011, 02:24:50 pm »
Thanks for your responce. Will check the spelling. Can you clarify that this is an early 80's 1.6 head, not a 1.8? I have known my machinist for over 30 years. I trust him completely. He said the crack was no problem.
Reply #3April 15, 2011, 07:18:19 pm
maxfax
  • 2126
« Reply #3 on: April 15, 2011, 07:18:19 pm »
That is a 1.6 liter head..  There was no 1.8 diesel, and all the 1.9 diesels had hydraulic lifters.. Since it has 12mm head bolts it should fit 1982ish and up
Reply #4April 15, 2011, 09:00:11 pm
GregMottin
  • 4
« Reply #4 on: April 15, 2011, 09:00:11 pm »
Thanks Maxfax
Greg
