either that, or possibly a crack in the head..
Hmm, did that, it opens slowly, but how do I know if it's open fully? not much really happened TBH, just the rubber on the shaft moved.And who thought it a good idea to put the thermostat on the BOTTOM of the engine?
They are cheap, they fail regularly, they are a pain to remove and install... me personally: I just install a new one and be done with it. Your symptoms certainly sound t-stat related, and Occam's Razor says the simplest answer to a question is usually the right solution. If your t-stat housing is plastic it's a good idea to replace it as well... it's even cheaper and loves to warp. Unbolt it and it will spring into a new shape and never seal properly again. BTDT.. twice.
gives you a good reason to inspect your coolant tho..the coolant still looked purple in my rabbit, but upon draining it, it wasnt purple/blue anymore.. it was BLACK.and if you have an aluminum water neck, then you can drill and tap it in the corner, and voila, instant drain plug!
Quote from: R.O.R-2.0 on April 12, 2011, 04:32:27 pmgives you a good reason to inspect your coolant tho..the coolant still looked purple in my rabbit, but upon draining it, it wasnt purple/blue anymore.. it was BLACK.and if you have an aluminum water neck, then you can drill and tap it in the corner, and voila, instant drain plug!Have a part # or application (vehicle on which it is original equipment) for the aluminum t-stat housing?
A1s and very early A2s... if you want one keep your eyes peeled at the local wreckers since they are NLA from VW.
