Author Topic: Is this a K24 or a K14 turbo?  (Read 3920 times)
April 10, 2011, 02:21:03 pm
Fredrikkk
  • 155
« on: April 10, 2011, 02:21:03 pm »
K24 or K14? Is it worth buying and running this at 20psi? That is, if it's a K24.
Thanks :D
1991 VW Golf Pasadena GTD - Yeah, it's awesome.
Reply #1April 10, 2011, 02:23:27 pm
Re: Is this a K24 or a K14 turbo?
« Reply #1 on: April 10, 2011, 02:23:27 pm »
it *LOOKS* like a K24.. but that picture doesnt tell us much. a picture of the whole thing woulda been more useful..
Reply #2April 10, 2011, 02:30:28 pm
Fredrikkk
  • 155
« Reply #2 on: April 10, 2011, 02:30:28 pm »
I'm getting pictures from the guy selling it.
Will it be super laggy if I run it at 20 psi? Or I guess what's most important is: will the headgasket last at 20 psi?
Reply #3April 10, 2011, 02:43:53 pm
« Reply #3 on: April 10, 2011, 02:43:53 pm »
its a toss up. you might get lucky. my Audi has a K24, 25psi boost, and it still has a stock head gasket.
my rabbit is running a VNT, maxes out at right around 20 psi.. my head gasket is still intact..
its going to be laggy tho, not bad, but its not going to be like a K14 or a K03..
Reply #4April 10, 2011, 02:47:42 pm
Fredrikkk
  • 155
« Reply #4 on: April 10, 2011, 02:47:42 pm »
I see, I see :)
The turbo comes with a manifold and wastegate; do I need the K24 oil return line too?
And secondly, how would I remove the watercooling from the K14?
Reply #5April 10, 2011, 06:45:16 pm
« Reply #5 on: April 10, 2011, 06:45:16 pm »
i don't think they are laggy, its not like instant boost or but as the engine spool so does the turbo,  and i could hit 20-30psi well before the engine was close to red line.  i'd rather have a laggy turbo down low anyway and have more power in higher gears, cheap traction control haha.  k24 is a sweet turbo tho imo, good match for a 1.6 beyond our stock turbos it's hard to find something that will make the boost we need effeciently with out passing the surge line.
Reply #6April 11, 2011, 12:35:28 am
Alcaid
  • 549
« Reply #6 on: April 11, 2011, 12:35:28 am »
That is NOT a 1.6TD K24, the comp housing part# should be 5324 101 5014
'10 VW Passat 1.6TDI Highline
Reply #7April 11, 2011, 12:47:13 am
Fredrikkk
  • 155
« Reply #7 on: April 11, 2011, 12:47:13 am »
Å jasså?
What kind of turbo is it then?  ???
Reply #8April 11, 2011, 01:00:00 am
Alcaid
  • 549
« Reply #8 on: April 11, 2011, 01:00:00 am »
Do you have more pictures/numbers of it?
mvh
Petter
Reply #9April 11, 2011, 02:48:05 am
Fredrikkk
  • 155
« Reply #9 on: April 11, 2011, 02:48:05 am »
I don't but there is a link on bilforumet under parts for sale. There is a guy on VACN buying it!
Reply #10April 11, 2011, 03:40:22 am
Alcaid
  • 549
« Reply #10 on: April 11, 2011, 03:40:22 am »
Not much info there, guess we'll see when the new owner takes a closer look on it :)
Reply #11April 11, 2011, 11:52:38 am
Fredrikkk
  • 155
« Reply #11 on: April 11, 2011, 11:52:38 am »
It's official: it's a K24.
But I can't afford it, so no nice big turbo for me :(
