Author Topic: Vortex td pump.  (Read 4176 times)
April 05, 2011, 06:59:54 am
ein bora
  • 377
Vortex td pump.
« on: April 05, 2011, 06:59:54 am »
This may or may not interest someone. Seen it - thought it may
http://forums.vwvortex.com/showthread.php?5121172-FS-mk3-TD-pump
If you can't take advice - then you can't be helped!
Reply #1April 05, 2011, 06:07:48 pm
nathan_b
  • 361
Re: Vortex td pump.
« Reply #1 on: April 05, 2011, 06:07:48 pm »
not a bad deal at all, I wouldn't mind having those lines to try out some dual stage injectors in my frankenmotor..
Reply #2April 06, 2011, 08:10:32 am
Re: Vortex td pump.
« Reply #2 on: April 06, 2011, 08:10:32 am »
they still gotta be modified to work with a 1.6 pump.. they are not a direct bolt on affair.
Reply #3April 06, 2011, 03:29:26 pm
ToddA1
  • 434
Re: Vortex td pump.
« Reply #3 on: April 06, 2011, 03:29:26 pm »
Any downside to running that pump on a na car?  I figure if it never sees boost, no additional fuel will be fed.... correct?
-Todd
Reply #4April 07, 2011, 10:57:11 am
Re: Vortex td pump.
« Reply #4 on: April 07, 2011, 10:57:11 am »
-Todd
it will never be possible for that pump to deliver full fueling without boost. they make for gutless n/a engines.
Reply #5April 08, 2011, 12:29:54 pm
Re: Vortex td pump.
« Reply #5 on: April 08, 2011, 12:29:54 pm »
also... in usa.. 89-91 diesel the na had turbo pumps while the "eco" had na pumps.. why.... no boost on turbo pump kept it soot free and boost with no enrichment = no soot due to being lean..
gotta love epa stupidity..
so reality is any td pump can be used on a na.. and for best performance a td pump should be on all td..
